11.48 tonight
Old Sep 4, 2005 | 02:19 AM
aruba's Avatar
11.48 tonight
well another 11.48
reaction .552
60ft1.564
1/8 7.352
1/4 11.487
mph 119.33
street port
t60-1
24psi 450 hp
c16 mixed with pump gas
on et streets
IN ARUBA
Old Sep 5, 2005 | 10:06 AM
aruba's Avatar
guys what ring and pinion r u using
we are only shifting into 4th gear at the end of the track
should i just try to make more power or change the ring and pinion
another question
who street drives a bridge port ocationly in an fd?????
just wanted some input
Old Sep 5, 2005 | 11:52 AM
1wide7's Avatar
thats were i shift into 4th at almost at the end with 4.10 rear, some people use 4.30 and that will get you into 4th sooner
Old Sep 5, 2005 | 12:54 PM
Mordachai's Avatar
_
man, that's some great time....
|M|
Old Sep 5, 2005 | 01:02 PM
Snook's Avatar
Tony Stewart Killer.
That's a fast time but you are running way too much boost and your launch is way too good for that 1/4 mile time.
I ran a 11.8 when my car wasn't even running right with 15-16psi on pump gas and a 1.8 60 time. I also lost all power after the launch temporarily because the fuel went to the back of the tank. I would have had an 11.6 on that run when compared to my other time slips. With your launch and my car not having the fuel pressure drop problem and being tuned extremely rich to compensate I would have been in the 10s at the same boost levels with pump gas. I also doubt your small turbo can pump out more than 20psi efficiently.
Old Sep 5, 2005 | 03:58 PM
rajeevx7's Avatar
2 FD's since '98
Oh shizzy Snook....why don't you tell him what you really think!
Old Sep 5, 2005 | 04:07 PM
Mordachai's Avatar
_
There's a guy on this board who fabbed a special tank with baffles in it, so if you went left, right, gassed it, or hit brakes, the gas would flow under these hinged baffles so that the gas was always at the center lowest point, to avoid gas starvation. IT was for a 3rd gen, all made out of Aluminum IIRC, but he said with the time and cost involved he wouldn't even think of making another one. But man, it is a work of art in it self.
I can't seem to remember who it was that did this.
Maybe he'll speak up..................
Old Sep 5, 2005 | 06:10 PM
Snook's Avatar
Raj: I'm just guessing if I had run 24 psi with racegas and my car running perfect like it did in the end with a 1.5_ 60 foot I think I would have gotten in the 9s lol...realistically mid 10s
Thanks brother. I remember reading that thread a while ago. I'm out of RX-7s now. You really don't need any of that **** any way. I wasn't planning on launching that hard that's why I only had 1/2 tank. After that launch I went and got another 1/4 you should always have 3/4 tank when launching hard at the track. If you have **** tires and you spin you don't need but 3/8 tank but with DRs or slicks when the car takes off you need at least 3/4 tank.
Old Sep 5, 2005 | 07:53 PM
aruba's Avatar
WELL WHAT CAN I SAY
WE HAD THE SAME PROBLEM TO
the car was backfiring
it was low on gas
so now we keep it filled up never had this happen before with any other car
well the turbo is a tubonetics 60-1
the boost varies a bit like between 20-25
i know with this power we should be in the 10s with these 60fts
but what now?????
change out the ring and pinion or go back and make more power???
Old Sep 5, 2005 | 08:31 PM
ROTARYFDTT's Avatar
Ding King
Originally Posted by aruba
WELL WHAT CAN I SAY
it was low on gas
but what now?????
With a 60-1 and 24 pounds on pump/C16 you should be around 125MPH I would think.
Do you know the specs on the 60-1?
In my personal opinion, the car doesn't seem to be tuned right or if its a smaller 60-1 the motor is outflowing the turbo.
Old Sep 5, 2005 | 08:40 PM
aruba's Avatar
on the out flowing the turbo i think your right
on the dyno it feels like its not boosting more when we crank it up
i really had to turn the **** from the dna boost controller just to get it from 20 -25 psi
well rolo from CFT tuned the car like 2 months ago
HE SAID THAT WE NEEDED A LARGER TURBO
Old Sep 5, 2005 | 09:00 PM
ROTARYFDTT's Avatar
Ding King
How big is the port you have on your car, and do you know what a/r the exhaust side is on the 60-1. Regardless though, a 60-1 is a smaller single for an FD. Sounds to me more and more like your flowing too much for the turbo.
If you wanted to get a few runs in at lower boost levels, you could see where the turbo is dropping off and confirm the motor outflowing the turbo.
Old Sep 5, 2005 | 09:30 PM
aruba's Avatar
thanks man i will just get a larger one
thanks for the help
Old Sep 6, 2005 | 03:56 PM
2FAST7S's Avatar
a 4.33 will get you better times. You will have less of a waste going into 4th at the end cause not only will you fall into the powerband but you will also shift a bit sooner and stay within it longer. As it is most of us with the 4.10 are barely going into 4th just before the trap...I even tried to just redline it out and made little difference. Whatever i gained by not shifting i lost by rev limit(should have raised it to 8,800)
Old Sep 7, 2005 | 06:41 PM
aruba's Avatar
thanks man
Old Sep 7, 2005 | 10:18 PM
Definitely a bigger turbo. You should be trapping 119 at like 15-17 psi.....
Old Sep 8, 2005 | 11:11 AM
rotorbrain's Avatar
fart on a friends head!!!
man, i dont like hearing this stuff about a bigger turbo. . . i JUST got a 60-1 on mine and if this thing doesnt perform. . . im just gonna pull it out and spit on it!!!!. . . maybe even drop some heat on it!!!!
Old Sep 8, 2005 | 12:46 PM
Snook's Avatar
I think a 62-1 is just right : )
Check my sig
Old Sep 8, 2005 | 02:37 PM
rotorbrain's Avatar
ppppppsssshhh. . . yanni, my wife would kill me if i tore it apart again!!!! and my unborn son would flip me off. . . cause his diaper money would be lost in my car somewhere. hahahaha
Old Sep 9, 2005 | 08:34 AM
he's just trying to push too much boost through that turbo. You'll be fine with the 60-1 as long as you are happy with an 11 second car .
Old Sep 10, 2005 | 07:10 PM
aruba's Avatar
we just wanna go faster on the street it spools quick compared to my car
i have a pt 70 mm
the 60-1 spools quick
Captain Hook
13
Oct 4, 2015 06:35 PM
risingsunroof82
22
Sep 22, 2015 01:20 PM
chiefmg
Sep 10, 2015 07:46 AM
