noise supression
Old Sep 4, 2005 | 12:47 AM
riceburner1r2001's Avatar
Question noise supression
i am planning on getting the xm radio set up and wondering with the noise i have now from from magnecor wires will i still have it when i install the xm.. thanks
Old Sep 4, 2005 | 02:29 PM
bump
Old Sep 4, 2005 | 03:03 PM
potatochobit's Avatar
your magnecore are regular street wires or race wires? you probably wont notice either way.
Old Sep 4, 2005 | 06:29 PM
pncg 90 gtu's Avatar
wire noise
use a really good ground locate it close to the unit , the stock ground wire will not be good enough..that should fix the potential problem also make sure youre power leads are not close to any other electrical sources....
Old Sep 9, 2005 | 07:10 AM
Iggy76's Avatar
xm doesn't work on FM frequencies... you shouldn't have to worry about any induced noise. Make sure you have a good ground for the radio and any amps.
Old Sep 9, 2005 | 11:20 AM
David Beale's Avatar
My Magnicor (street) wires supress noise better than the stock carbon core wires. I don't think you have anything to worry about.
When installing a new audio system, I always like to run 12 gauge or larger wires directly from the battery (fuse inline on +ve lead at battery) - both +ve and -ve leads run into cabin. There I install a relay with the coil connected to acc. Then I know I have "clean power".
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
Linda_Lovelace
Sep 18, 2015 10:04 PM
zxrazorxz
Sep 14, 2015 07:21 PM
