What bolts do you use on your turbo
Old Aug 31, 2005 | 04:25 PM
spoolin1012's Avatar
I need to know if there is special heat treated bolts that go on a single turbo manifold or can i just go to homedepot and pick some bolts up. Just wondering.
Old Aug 31, 2005 | 06:16 PM
bcty's Avatar
Boost This!
any high grade SS bolt should do
just make sure you get some "stovers" i think they call them for nuts so they dont back off
Old Aug 31, 2005 | 07:52 PM
su_maverick's Avatar
Back in the 7 life again
dont go to home depot... go to a really high end supply store that will have a good supply.
Old Aug 31, 2005 | 10:00 PM
Carl Byck's Avatar
Mad Man
I'd avoid stainless, too soft, and it galls at the drop of a hat. Get OEM bolts from Mazda.
Old Aug 31, 2005 | 11:43 PM
This if for aftermarket turbo.. I have a 60-1 here that needs to be mounted on the manifold. I need some screws to mount it. So a turbo/performance shop should have what im looking for then. Or does anyone know of a place online where i can purchase them from. Thanks.
Old Sep 1, 2005 | 12:22 AM
IRPerformance's Avatar
Sponsor
Ace Hardware usually has a good selection, especially if you need grade 8 and metric. Remember to use anti-sieze. That turbo will be comming off again at some point
Old Sep 1, 2005 | 12:46 AM
Bacon's Avatar
IRS 4 Life
www.mcmastercarr.com
Old Mar 15, 2010 | 12:20 PM
muibubbles's Avatar
Bubblicious DEF.
holy reviving....
what thickness bolts are you guys using? are you using a bolt with a nut or the double threaded studs with 2 bolts? can i get these from jegs?
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
