225's up front ok?
Old Aug 22, 2005 | 01:57 PM
spot_skater's Avatar
The Cause of Death
225's up front ok?
I just want to double check before I go out spending the cash for these tires.
I've got an 88 SE, Eibach Springs, Tokico shocks, 16x7" wheels with a +40mm offset.
I want to get 225/50/16 all around...anyone see any problems with this?
Thanks in advance,
James
Old Aug 22, 2005 | 02:35 PM
Funkspectrum's Avatar
I have the same tire size on mine and I have no problems with it except for a little rubbing when you turn the wheel all the way....
Old Aug 25, 2005 | 07:26 PM
DarkKnightFC's Avatar
And the Revolution...
I ran into this problem. I purchased some Avons 225/50's all the way around. I had problems with the front rubbing pretty hard especially in turns that put a lot of load in that direction. I attempted to roll the fenders a little bit but it was rubbing too much and eventually cut the tread of the tire down on the outside. I ended up running KDW's in the front because they offered a 45 series whereas Avon did not. I do have AGX's and Tein springs.
Chris
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
