1200cc injector install
Old Jan 14, 2002 | 11:12 PM
suganuma's Avatar
no
installing a pair of 1200cc injectors soon.....wondering if anyone has any tips or info
what i know so far:
depressurize fuel system (short some wires - have to search around to find out exactly which)
loosen 2 screws holding the injector in
wiggle it out from the o-ring seal
put new one in
tighten screws
pressurize system and visually check for leaks
is there a better way to check for leaks or to prevent them?? i dont want to have leaking fuel and risk an engine fire.
thanks
Old Jan 15, 2002 | 10:10 AM
Sled Driver's Avatar
The Anti-Prius
Not quite that easy
To depresserize your fuel system you pull the green relay from the box next to the L/H shock tower.
That, in it's self, is a bitch! There is no room to grab it & the case is made from egg shell thin plastic!!!
Start the car & it will die after a bit, (runs out of gas).
Pull the upper intake manifold & remove the screws holding the secondary injector retaining caps. Pull the wire connectors off the injectors
Now the real fun begins.
Try to remove the injectors, without ******* them up.
You can grab the head with channel lock pliers, try prying under the head with a screw driver, twist & tug, whatever.
I pulled the fuel rail & tried to push them out from the bottom. All I did was crack one of the nozzel caps! Mine felt like they were welded in.
Buy new O-rings from MazdaTrix or the dealer. Don't try any generic O-rings from the injector shop or autoparts store.
TRUST ME, they will leak & you will be taking everything apart, again & again!!!! They look the same, but are a mm or two smaller.
Good Luck
Old Jan 15, 2002 | 12:39 PM
Rotary93's Avatar
Retired RX7 mechanic
If you need to use a little penetrating fluid and twist them out...
Old Jan 15, 2002 | 04:53 PM
paw140's Avatar
I just removed my two primary injectors last night, and it is a BITCH and a half! I have the whole fuel rail system out of the car, so its a little easier. I ended up spraying WD-40 around the top of it, let it sit for a couple hours, and they still wouldn't come out. I had to twist and pull really hard, and pry a little with a screwdriver without screwing it up. It took me about 30 minutes to get the two injectors out, and my hands aren't feeling to good today.
I don't think I would have been able to remove them while the fuel rails were still bolted to the engine.
Now I have to remove the secondaries...
Paul
Old Jan 15, 2002 | 05:34 PM
suganuma's Avatar
no
let us know if the experience with the secondaries goes any better for you....
Old Jan 15, 2002 | 06:56 PM
Rotary93's Avatar
Secondaries are 1000X easier..'Dont remove the fuel rail...
Old Jan 15, 2002 | 07:39 PM
paw140's Avatar
Rotary93 was right. The secondaries came out a lot easier. I sprayed a little WD-40 around the top, and it still took a lot of persuasion (pulling, twisting, and prying with a screwdriver), but it only took me about 5 minutes to take them both out.
Paul
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
