20+ Psi Ignition
Old Aug 15, 2005 | 05:48 PM
Bacon's Avatar
IRS 4 Life
20+ Psi Ignition
Searched, minimal information turned up
Going to be heading north of 20 Psi soon and want to make sure my ignition system is up to par. (Probibly going for 25Psi)
I’m running a Haltech E6K wired right to the igniter, Stock FD coils, Taylor Spiro pros, 10.5’s all around.
No ignition break up or problems @ 18Psi but figured now was better than ever time to upgrade.
More powerful coils? How much can the stock one hold up to. Properly tuned of course ;-)
Old Aug 15, 2005 | 06:04 PM
nyt's Avatar
nyt
as for ignition i've seen the FD igniter with an MSD 6a on the leading support over 20 with FC coils.. i've seen the same setup with MSD coils run over 40.
Old Aug 15, 2005 | 07:35 PM
RexRyder's Avatar
ran 25 psi for a couple weeks. stock fc ignition w/ 10.5 magnecore wires. t04e 60 trim .96 a/r on pump gas.
Old Aug 15, 2005 | 07:46 PM
angelrx7HEAVEN's Avatar
V8 con
From: NYC home of thugs, killerz, and world leaders...and the fastest cars
i would say as a reliability mod get a the hks twin ign or an msd box at least for the main coil
Old Aug 15, 2005 | 09:21 PM
Poweraxel's Avatar
First: run (4) Crane boxes and (4) Crane coils
turn off the multi spark option by setting the dials to 0,1
Second: Run colder race plugs minimum 10's
works wonders!
Old Aug 15, 2005 | 11:07 PM
Bacon's Avatar
IRS 4 Life
Which HI-6? Which coil?
Old Aug 16, 2005 | 12:09 PM
BLUE TII's Avatar
Rotary Motoring
I am running a Crane Hi-6 and LX92 coil per leading plug and stock FC trailing ignition.
It really can fire through anything. You can run ridiculously rich and still make lots of power.
It will eat plugs quickly ~ 4,000 miles and my iridiums were nearly halfway through the ground strap (change plugs with oil). I will try it with the stock style semi-surface discharge plugs to see if they last longer.
Old Aug 16, 2005 | 01:16 PM
Carl Byck's Avatar
Mad Man
OR, I have no break-up running my E6K with 3-MSD6A(1 lead/2 trail), stock coils, and the Haltech for the igniter. I use Magnecore 10mm race wires, and 6725-11.5 plugs. I regularly see 20-25 psi, and I am running 10.5:1 after~7000 rpm, mid 11s elsewhere on 111 octane. My dynos are as smooth as glass with no smoothing on both a dynojet, and a dynapack. Carl
Old Aug 16, 2005 | 03:02 PM
YayeR's Avatar
it's my understanding that the Hi-6 and the Hi-6S are for cars with distributor, and the Hi-6DI2 is for distributorless ignitions.
Old Aug 16, 2005 | 05:01 PM
nyt's Avatar
nyt
I have used this setup as well and can vouch for it.
Old Aug 16, 2005 | 05:58 PM
Bacon's Avatar
IRS 4 Life
So remove the stock igniter connections and use the Msd boxes as the igniter? Like connect the White wire from the Msd box to the ignition out (L) and dig out(T) From the haltech?
Wow that easy?
Old Aug 16, 2005 | 10:40 PM
LETHAL RX7's Avatar
I have a nice jacobs box that i ran in my car that i will sell... im selling it bc im doing a completely diff. engine all together so....
Greg
Old Aug 16, 2005 | 11:45 PM
Carl Byck's Avatar
Mad Man
Old Aug 16, 2005 | 11:59 PM
nyt's Avatar
nyt
Greg
... why are you posting here? I hope youre joking about the jacobs box
Old Aug 17, 2005 | 07:41 AM
RETed's Avatar
No.
"HI-6" = single-channel CDI
"HI-6S" = single-channel, inductive - NOT CDI
"HI-6DI2" = two-channel CDI
-Ted
Old Aug 17, 2005 | 08:07 AM
RX7MONSTER's Avatar
Crane Cams HI-6 CDI ( get two of them)
good for 3bar boost
Old Aug 17, 2005 | 03:26 PM
YayeR's Avatar
Originally Posted by RETed
No.
-Ted
Thank you, that's what I needed to know The descriptions on the websites I found the crane products on were kind of confusing.
Old Aug 17, 2005 | 05:38 PM
Zero R's Avatar
Just in time to die
works wonders!
This setup felt like the car was a electric motor it was sooo smooth.
Old Aug 17, 2005 | 10:53 PM
RETed's Avatar
Yeah, Crane Cams like to be really vague about their ignition boxes.
Too bad, they make decent stuff.
-Ted
Old Aug 19, 2005 | 09:17 AM
Bacon's Avatar
IRS 4 Life
So hook the Hi-6 up like a points system, Now Do I wire the white wire from the Hi-6 to the haltech or from the wire coming from the igniter (bypass stock igniter? Or wire after igniter?) I would think that the Hi-6 would become the igniter but in the Hi-6 manual it says to hook the white wire up to the wire that went to the stock coil (after ignitor)
Thanks guys
Old Aug 19, 2005 | 12:23 PM
BLUE TII's Avatar
Rotary Motoring
For the E6K and HI-6 combo on a TII as I did you keep the stock ignitor and use the ignitor output as the HI-6 input.
Since the ignitor looked dopey with the coil removed off the top I put a nice black heatsink w/ thermal compound on the top of it. I later did read that ignitor can get really hot so maybe heat is more than rice?
Old Aug 19, 2005 | 02:55 PM
Bacon's Avatar
IRS 4 Life
Its for a FD but the ignition system setup should be the same for fd/fc
THANKS!
Old Aug 19, 2005 | 05:15 PM
RX7MONSTER's Avatar
Haha, yes. This is crane cams for yah
My car was sooo smooth it was awsome and also the MoTeC helped.. too bad i sold the setup
Old Aug 19, 2005 | 11:04 PM
Bacon's Avatar
IRS 4 Life
crane p#'s 6000-6400(HI-6) and 730-0892(LX-92 coil) right ones?
Old Aug 20, 2005 | 05:13 PM
Bacon's Avatar
IRS 4 Life
Ill be Quiet after this one gets answered, i promise
