FC rear camber gain
Old Aug 9, 2005 | 09:52 PM
andrewb70's Avatar
FC rear camber gain
I was wondering if anyone has ever actually ploted rear camber gain as the suspension goes into compression. My main concern is with excessive camber gain as the car squats in a drag racing set-up. I have video tapes of my car during a launch at the drag strip and the rear squats substantially.
Current setup consists of stock springs and Tokico adjustable struts with the fronts on full soft and rear on full firm during racing. Bogart wheels and MT drag radial tires in the rear.
Thanks,
Andrew
Old Aug 10, 2005 | 07:40 AM
Travis R's Avatar
trying to build a racecar
I've been meaning to measure everything and put it into SolidWorks (3-D CAD program), but haven't gotten around to it yet.... Heck I just transfered the title yesterday and I've owned the car for 3 years.
Old Aug 11, 2005 | 09:08 PM
andrewb70's Avatar
Anyone? Its hard to imagine that noone has actually measured this. Any guesses? 1 degree per inch of travel? 1/2 degree? more? less?
Andrew
Old Aug 12, 2005 | 12:23 PM
Carl Byck's Avatar
Mad Man
Andrew
For a rough answer, you can measure the camber, lower the car in 1/4 increments, and get the rough gain. You can grease the shock piston just before running to see how much squat you are getting on launch. If I were drag racing an FC, I'd make friends with crispeed, and get that sort of data via the friendship . Carl
Old Aug 14, 2005 | 09:21 PM
andrewb70's Avatar
Thanks for the help. I was trying to avoid going through the process of taking the measurements. It's a little surprising that noone has done this before.
Andrew
Old Aug 14, 2005 | 10:21 PM
M's's Avatar
M's
i don't think many people in this section are drag racers, but the information is beneficial to all racers so who knows. How about some 2-piece uprights?
Old Aug 15, 2005 | 08:22 PM
andrewb70's Avatar
What would a 2-piece upright do for you?
Andrew
Old Aug 16, 2005 | 06:47 PM
M's's Avatar
M's
do a search for michelin formula one two peice uprights.
Old Aug 16, 2005 | 07:16 PM
Gene's Avatar
10 lb. boost, 5lb. bag
Uprights? The rear suspension is a semi trailing arm multi-link thingie, not double a-arm like F1 cars.
Old Aug 16, 2005 | 08:59 PM
M's's Avatar
M's
i know that, but that's the only way to eliminate camber gain on acceleration and still handle well
Old Aug 17, 2005 | 10:55 AM
Travis R's Avatar
What about anti-squat?
Old Aug 17, 2005 | 11:12 AM
RX-Heven's Avatar
I'll blow it up real good
Then you eliminate weight transfer needed for additional traction when launching.
Old Aug 17, 2005 | 11:16 AM
Travis R's Avatar
No you don't. Weight transfer is unaffected.
The only things involved with weight transfer are CG height and wheelbase (or track width for lateral transfer).
Old Aug 18, 2005 | 11:52 PM
Freak'n Big Panda's Avatar
Yeah it's a common misconception that weight transfer is related to the amount that a car dips or sways during acceleration. The stiffness of your suspension does absolutely nothing in regards to weight transfer.
Old Aug 19, 2005 | 01:53 PM
RX-Heven's Avatar
You two are correct, sorry for the misinfo.
fwiw, Longitudinal Load Transfer = Acceleraction(g) x [(Weight x CG Height) / Wheelbase]
primerGrey
Aug 25, 2015 02:46 PM
RaY358
Aug 19, 2015 11:44 PM
