West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Could anyone from sacramento help me with my boost problem
Old Aug 5, 2005 | 09:51 PM
Xearo_FD3S's Avatar
I know, youre sorry...
Im having a problem with my car not getting any primary boost. Ive tried to fix it myself, but since I have no idea what the problem is I was wondering if someone would be kind enough to come help me. I have a 93 r1. Thanks everyone.
Old Aug 5, 2005 | 10:03 PM
RotaryEvolution's Avatar
Sharp Claws
don't trust mazda to warranty their own work?
i will probably be down at the dori ***** bbq on sunday if you can swing by i could probably take a look at it real quick but no guarantees if i can fix the problem, it is probably a vacuum line mixed up. it is easy to get the vacuum lines mixed up while doing a rebuild.
Old Aug 5, 2005 | 10:16 PM
Sharp Claws
hmm, maybe/maybe not. my brother called and is coming up here tomorrow so i may be busy on sunday but we will see.
if anything, you could bring me the car and i can trace out the vacuum sources and see if that is the problem. might take a few days to check everything over thoroughly.
Old Aug 6, 2005 | 01:30 PM
Xearo_FD3S's Avatar
Its cool man, I got a cool diagram with all the hoses in color and really easy to read so I think im just going to use that to help me locate the broken hoses. Might be an actuator problem but its probably a hose. Ill let you guys know when I get it fixed.
Thanks.
Old Aug 9, 2005 | 06:24 PM
Axis8758's Avatar
Any luck with your problem?
Old Aug 9, 2005 | 07:53 PM
Xearo_FD3S's Avatar
Im taking it to the mazda dealer so they can figure it out. They put the new motor in so they can do their own repair work. Probably just a loose vac line or bad check valve but I dont want to have to take apart half the motor to try and find it.
Old Aug 9, 2005 | 08:11 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Hope that you get the boost problem fixed. Was it screwed up when you got the car back or did it happen later?
Zach
Old Aug 11, 2005 | 03:32 PM
Xearo_FD3S's Avatar
Its not fixed yet.. I told him (the mechanic) to go over any vaccuum lines and anything that had to do with the turbo. He said it felt fine to him when he drove it but I know what it is supposed to feel like. So I am going to take it back there and have him take off the turbos to check them for cracks in the housing and a little bit more of an extensive investigation. Other than that I am stuck driving my car with a boost leak till monday =( luckily I dont have to drive that much and I am going camping this weekend.
/rant
edit: no my car was fine when I picked it up from having the engine put in... the mechanic knows a lot about rx7s, just not what it is supposed to feel like to someone who drives it everyday like meh.
Old Aug 11, 2005 | 09:54 PM
dohc-vtec_eg's Avatar
if ur not hitting primary boost at all then its ur vac lines in teh nest. i assume u have a boost gauge right? man with out primary boost FD's shouldnt be DD fucken garbage with out it
Queppa
Nov 18, 2024 03:47 AM
sherff
Sep 12, 2015 12:22 PM
AXA
Sep 5, 2015 10:06 AM
tiger18
Sep 3, 2015 08:27 PM
rx7shirley
Sep 2, 2015 02:11 PM
