My R85 Dyno numbers
Old Aug 2, 2005 | 11:11 AM
aREX4X's Avatar
My R85 Dyno numbers
The KG parts R85 turbo kit. Steve Kan Tuned.
Stock reman, 3" exhaust with 2 muflers, Greddy 2 row FMIC, 1680s with 550s, Supra Fuel pump. I think that's all that's relative.
Curves look great to me, I am Satisfied with the results.
X...
Old Aug 2, 2005 | 11:22 AM
Carl Byck's Avatar
Mad Man
Interesting, what do you think is up with the torque? It should be near flat or rising til much later in the RPMs IMHO. Witha stock port motor, perhaps a smaller hotside is in order... GL, Carl
Old Aug 2, 2005 | 12:01 PM
aREX4X's Avatar
Actually I'm quite happy with the results. With this setup I right at the threashold of traction on street tires. Some colder (60F) nights I start to get wheelspin on full boost in 2nd gear, but other than that I can even floor it in first and not waste time spinning tires. I think if I upped the torque things would be different. Besides in the distant future I plan to go to a built motor with some high boost and get a little out of hand.
X...
Old Aug 2, 2005 | 12:12 PM
RETed's Avatar
Small turbine A/R?
0.82 or something?
I don't think this is a 1.06 turbine A/R, right?
-Ted
Old Aug 2, 2005 | 12:29 PM
pluto's Avatar
Those #'s look pretty good for a stock ported engine. Who needs dyno chart when my butt dyno is within 1%. j/k...
Old Aug 2, 2005 | 12:42 PM
dubulup's Avatar
development
how much boost?
Old Aug 2, 2005 | 12:52 PM
pluto's Avatar
His chart shows anywhere from 16-17psi. You can see the boost curve on the second sheet.
Originally Posted by dubulup
how much boost?
Old Aug 2, 2005 | 01:08 PM
maxcooper's Avatar
WWFSMD
Originally Posted by RETed
Small turbine A/R?
0.82 or something?
-Ted
It is a 1.15.
-Max
Old Aug 2, 2005 | 05:08 PM
sevenin7's Avatar
X...
Very good job , aREX4X !
Are you running with PFC ?
Old Aug 2, 2005 | 05:13 PM
sevenin7's Avatar
Originally Posted by maxcooper
It is a 1.15.
-Max
Hi Max , whats up ?
Are you still running with the same boost or higher ?
Old Aug 2, 2005 | 05:17 PM
aREX4X's Avatar
Yup, Power FC for some trouble free modding.
X...
Old Aug 2, 2005 | 05:23 PM
sevenin7's Avatar
X...
.......i see , but you have Steve , and he is a excellent tuner !
Old Aug 2, 2005 | 05:56 PM
cripsR6's Avatar
11.7@128
X...
Congratulations! I was actually contemplating purchasing this kit, but never recieved a response to an email I sent. It was probably very vague and annoying though, so I understand why. Good luck, and be safe.
Old Aug 2, 2005 | 10:12 PM
aREX4X's Avatar
yeah, sorry... I wanted to wait till I had some solid info on the car and not just "it should be making" Kinda ****.
X...
Old Aug 2, 2005 | 11:03 PM
1QWIK7's Avatar
White chicks > *
saw the video of your car vs the z06
VERY NICE!!!
Old Aug 3, 2005 | 03:39 AM
RETed's Avatar
It is a 1.15.
T04 flanged?
-Ted
Old Aug 3, 2005 | 07:41 AM
TEZTnTUNE's Avatar
BUILD, TUNE, RACE, REPEAT
its the scaling and shape of the graph that makes it look like the torque drops rapidly. that is a very good tune.
Old Aug 3, 2005 | 08:40 AM
pianoprodigy's Avatar
Missin' my FD
I added you to my ongoing dyno comparison chart.
Old Aug 3, 2005 | 10:14 AM
aREX4X's Avatar
Sweet! Glad I could help out. I might do a couple more pulls to see if the boost spike had anything to do with the top end of the graph.
X...
Old Aug 3, 2005 | 10:33 AM
pluto's Avatar
Why is there such a big spool up difference between max's car and apex's car? I tuned both myself. Weird.....
Old Aug 3, 2005 | 10:41 AM
Missin' my FD
Edit: nevermind
Old Aug 3, 2005 | 11:03 AM
pluto's Avatar
I just noticed that apex's car made alot of torque for the boost level he's running.
Old Aug 3, 2005 | 12:40 PM
rotorsownyou7's Avatar
Slow RX-7
Does the KG parts car make more power because of the port, I see it makes power longer. What should the R85 make on a street port at 15 PSI?
Old Aug 3, 2005 | 12:43 PM
Missin' my FD
Not sure, but I think the KG Parts car had an aftermarket intake manifold. Can anyone confirm or deny?
Old Aug 3, 2005 | 01:04 PM
rxrotary2_7's Avatar
Yes the original sheet was using a street port and had a Jaytech intake.
We have a local guy with a streetport running at 22/23lbs of boost and trapping 133mph with the stock intake tuned by Dee. We have to get a video of the car running or on the dyno. Reason there is not any rush to make a video is because no matter what is posted, it is always questioned/picked apart.
