Sponsored by: CARiD
air/induction questions......
Old Aug 2, 2005 | 06:46 AM
dubber91's Avatar
hi there, i am in the middle of fitting a RX7 13b injection engine into a different car and have found the unduction system to be awkward in placement. Basically, i need a flage from the throttle butterfly going the other direction from the stock 13b one so i can modify the air flow meter in order for it to sit horizontally. I notice that the turbo RX7s induction system is on the other side of the engine bay, thus the first 90 degree angle would be suitable. Can anybody tell me if its possible to use one 90 degree fitting on the 13b engine? If so it would solve a lot of problems.
Cheers guys
Steve
Old Aug 2, 2005 | 07:53 AM
MPM's Avatar
MPM
Getting rid of the upper intake pieces would be so much easier. Have you considered a sidedraft carb? It would eliminate the need for the AFM and give you 4-5 inches of hood clearance.
Old Aug 2, 2005 | 07:59 AM
dubber91's Avatar
the whole reason i went for this engine was because it is fuel injection. It runs beutifully, its just a case of finishing it off now...
Steve
foreignracer
Mountain RX-7 Forum
60
Aug 29, 2008 06:50 PM
jkimbro
Sep 23, 2006 04:24 PM
