Power FC Need fuel advice
Old Jul 31, 2005 | 08:06 PM
nismorx7's Avatar
Need fuel advice
Hey guys i need your advice on somthing. I need to know if 1200cc secondaries will be enough for running 11psi on this set up.
custom mild street ported, newly rebuild motor with ceramic housing, etc...
t-58 turbonetics turbo, 0.70 compressor, 0.96 turbine
47mm wastegate, full exhaust,
power fc, the list is longer, just tell me what u need to know if u need more info.
Thanx alot guys, ive been doin some research on it but getting mixed messages on my setup for fuel. Thx in advance
Old Jul 31, 2005 | 09:08 PM
nismorx7's Avatar
woops, its an s5 motor....
Old Jul 31, 2005 | 11:39 PM
cewrx7r1's Avatar
Eye In The Sky
550/1200 are good for around 350RWHP with a slightly upgraded pump.
Should be good.
Old Aug 2, 2005 | 11:54 AM
nismorx7's Avatar
Alright thanks for the help, Any idea where to get the injectors and what modifications need to be done?
Old Aug 2, 2005 | 09:11 PM
cewrx7r1's Avatar
Eye In The Sky
If the secondary fuel rail is the same as a 93 FD, look in the 3rg gen for sale under
my handle. All that you have to do is make the PFC Commander changes and AFR tune.
https://www.rx7club.com/showthread.php?t=449194
Old Aug 10, 2005 | 09:16 PM
nismorx7's Avatar
Thanx alot cewrx7r1. Thanks alot for the info i needed. I wish i could use those injectors but the s5 ones are a completley different injector so i guess ill have to keep looking. Thx alot for the help though.
sherff
Sep 12, 2015 12:22 PM
SCinfidel
Sep 8, 2015 05:36 PM
