Power FC fan question....searched
Old Jul 28, 2005 | 07:16 AM
Master_Tao's Avatar
The Dude
I think the fans in my fd are set to come on at waaaaaay to high a temperature. I can't seem to find the settings on the commander though. the pfc came with my 7 so it didn't come with the manual. I did read apexi's version on the web but still couldn't find it.... so how do I change those pesky temperature settings?
Old Jul 28, 2005 | 09:37 AM
cewrx7r1's Avatar
Eye In The Sky
You need a datalogit to change the fan settings.
So for now, do the FAN MOD SWITCH mod.
Old Jul 28, 2005 | 10:19 PM
Master_Tao's Avatar
The Dude
you talking about the ac/3 mod?
Old Jul 28, 2005 | 11:31 PM
cewrx7r1's Avatar
Eye In The Sky
If you car had the cooling system recall, then on the back of the ECU was a little black box. It has a wire coming off it with an insulated female spade connector, but not used.
You run this to a switch to ground. This turns the fans on just as if the car had a water temp overheat problem. If turned on for over 2 minutes before turning the engine off, the fans will stay on for 10 minutes to cool down the engine.
Search on it!
I have the DATALOGIT and my fans at 86/86/88 and I have the switch.
Still use the FMS for extra cooling if racing in the heat as it kicks up the fan speed also.
Old Jul 29, 2005 | 12:16 AM
Master_Tao's Avatar
The Dude
sweet, thanks for the answer.
atticus_jay
Interior / Exterior / Audio
Oct 23, 2015 11:16 AM
rotor_veux
Sep 19, 2015 07:13 PM
