FC thermoswitch for FD
Old 02-19-05, 10:31 PM
RX-7 Bad Ass
DaleClark's Avatar
Received 2,437 Likes on 1,508 Posts
It's official - do NOT buy a Miata thermoswitch until you read this!
OK, I guinea pigged this one, and all worked out for the best .
As you may recall, I posted a while back that I saw in a copy of RX-7 Magazine from Japan that they were using the '89-91 FC thermoswitch as an upgrade. This jogged my thinking...well, fast forward to today. I got the thermoswitch last week and installed it today.
Here's the deal -
- SAME operating specs as the Miata switch
- BUT, uses the stock FD plug - NO CUTTING OR HACKING. Unscrew old switch, screw this one in, plug it in, you're done.
It was about $50 from Ray Crowe at Malloy Mazda (1-888-544-3400). He didn't have it in stock, so it took a day or two for him to get it and ship it my way. But, I explained the deal with the switch to him, and he was VERY interested - I think if he gets an order or two, this will be a stocked item soon. Part number is PN41-18-840. It's for the '89-91 RX-7, non-turbo or turbo.
Dunno if you can see on the pics, but the FD switch has "108" on it, and the FC switch has "95" stamped on it. That's the switch-on temps - 95 deg. C and 108 deg. C. Fans come on sooner, car stays cooler, engine stays happier.
It was a little bit of work to install. I removed the crossover pipe and alternator, then had access. Unplugged the old switch (you have to hunt for the "button" to unlatch the connector - it was on the under side of mine), used a 17mm closed-end wrench to break it loose, then unscrewed it. Some water was lost, but it was just water in the top of the thermostat housing. Put a little oil on the O-ring on the new switch (came with the switch, and it was already on there) and screwed it in. Plugged everything back together, put the car back together, good to go. Pulling the alternator was the most time consuming part - it's a little tricky to get out of there.
Anyhow, this is a done deal - the Miata thermoswitch is now a "dead mod" . Unless it's WAY the hell cheaper or something. I'd much rather have one that plugs right in just like stock!
Dale
Attached Thumbnails FC thermoswitch for FD-fcswitch1.jpg   FC thermoswitch for FD-fcswitch2.jpg
DaleClark is offline
Old 02-19-05, 11:29 PM
LS1 powered
kosoku's Avatar
I'm definately buying one.
kosoku is offline
Old 02-19-05, 11:30 PM
Cheap Bastard
adam c's Avatar
Good info Dale. I have been waiting for the results on this one Did you check it to make sure the fans came on at 210?
adam c is offline
Old 02-19-05, 11:33 PM
Sponsor
RX7Club Vendor
FDNewbie's Avatar
Dale, a BIG THANK YOU goes out to you for testing this out. I'm sure this will be added permanently to the "3rd Gen Reliability Mods" as the way to go
FDNewbie is offline
Old 02-19-05, 11:38 PM
RX-7 Bad Ass
DaleClark's Avatar
Yep, comes on at the right temp and everything - has the same operating properties as the Miata switch.
Dale
Old 02-19-05, 11:44 PM
Cheap Bastard
adam c's Avatar
Great find Dale
adam c is offline
Old 02-19-05, 11:45 PM
FD3SR1's Avatar
this needs to be one of the links under FAQ for 3rd Gen & other useful links!
FD3SR1 is offline
Old 02-19-05, 11:49 PM
REAmemiya FD3S's Avatar
Dale...thank you so much for getting an FD! since you've gotten the FD you've done so much to help our community...thanks again! Keep it coming!
REAmemiya FD3S is offline
Old 02-20-05, 12:03 AM
I'm a CF and poop smith
skunks's Avatar
what again does the thermoswitch do again? does it just turns on the fans automatically at a lower temp?
skunks is offline
Old 02-20-05, 12:10 AM
TT_Rex_7's Avatar
The thermoswitch turns on the fan at a given temp. The FD thermoswitch turns on the fans at 108 deg. C, and the FC thermoswitch turns the fans on at 95 deg. C.
-Alex
TT_Rex_7 is offline
Old 02-20-05, 02:33 AM
TT_Rex_7's Avatar
Originally Posted by superior force
question is who cares?
the car runs fine with the stock switch
Alot of people care
If you havn't noticed our cars run pretty damn hot. The FC thermoswitch allows the fans to turn on sooner to help insure the car doesnt over heat. Especially people with front mounts, and heavily modded cars.
-Alex
TT_Rex_7 is offline
Old 02-20-05, 02:37 AM
Living the Dream
ManGaZeRo's Avatar
Man dale your on a cooling mod roll. First you to the tb gauge mod/write up and now this, good stuff.
ManGaZeRo is offline
chris-reedtn's Avatar
kinda sad you left second gens, but still glad to see ya making a scene the the community as a hole.
-Chris
chris-reedtn is offline
Old 02-20-05, 02:38 AM
Hi....
jeremyb's Avatar
Reliability is everything on an FD. Having the thermoswitch make the fans come on at 95ºC especially for people that live in hot sunny *** areas all the time. Or people that encounter heavy traffic going to or from work. Thats like saying, "Why get a bigger radiator? The stock one is fine." Again, maybe YOU haven't encountered close-overheating problems, temp. rising in heavy traffic on a hot day, etc. But MANY MANY MANY other people have noticed cooling differences and appreciate people like Dale in discovering more and more upcoming ideas, write-ups and information to help out the rest of the Rx7 community. Go do a search about the miata thermo-switch and see how many people love the earlier temp that the fans go on. You'll also find that many people question how to wire the miata thermo-switch due to the switch having two wires and not one. This FC thermo-switch makes things alot easier as to not stir up confusion during the swapping process and to also serve the same purpose as the miata thermoswitch. So before you go doing the whole "who cares?" thing, have some support for your statement so people don't just straight flame you for something like what you just did.
Mad props Dale. I was looking into the miata thermoswitch mod and now seeing this makes things alot easier with the wiring . Annnd maybe the price?
Jeremy
jeremyb is offline
Old 02-20-05, 02:39 AM
No it's not Turbo'd
DCrosby's Avatar
Yes, Anyone with a Programmable Engine Management system, EMS...
Power FC, Haltech, Microtech, AEM, Etc... can change some settings in the programming of the EMS, to have the fans come on whenever you want.... so this is a Reliability mod for people with the Stock Computer (EMS).....
-DC
DCrosby is offline
Old 02-20-05, 02:40 AM
~17 MPG
scotty305's Avatar
So is there any good reason not to grab one out of a junked FC? What are the chances of an old thermoswitch failing?
-s-
scotty305 is offline
Old 02-20-05, 02:48 AM
RE13REW's Avatar
Maybe we could start a Group Buy for it .... can we ??
thx ANDY
RE13REW is offline
Old 02-20-05, 10:02 AM
Constant threat
bajaman's Avatar
I am definitely getting one of these.....
However, I am perplexed as to why I have a 115 degree switch? Maybe because of the automatic tranny?
bajaman is offline
Old 02-20-05, 10:09 AM
RX-7 Bad Ass
DaleClark's Avatar
You could get a switch out of an FC, but it might be a good idea to find a new O-ring for the switch to ensure a good seal. Dunno if Mazda sells that part, but I imagine if you go to an auto parts store with a selection of O-rings you could find one that would work.
That's interesting that you would have a 115 deg. C switch - I'll have to look into that one.
I'm still not 100% certain why Mazda tried to make the FD run SO hot. It may have been for fuel economy or something - a hotter engine gets better fuel economy. But, it really beats the hell out of all the other parts of the motor.
IMHO, if you can keep the temps reasonable, I believe that will promote longer engine life. Running over 100 deg. C may not be *bad*, but I think long-term it's not the healthiest for the engine.
I have other ideas on the fans as well - stay tuned. I've hopefully got some more good stuff on this one .
Thanks for all the positive feedback!
Dale
Old 02-20-05, 10:12 AM
Constant threat
bajaman's Avatar
Regardless, it is still SO cool that you found a lower temp switch that needs no mods and plugs right in....thanks Dale!
I know I will be getting one.
bajaman is offline
Old 02-20-05, 10:24 AM
PhoenixDownVII's Avatar
Angry
Thanks Dale, for fixing another Mazda engineering flake...
I don't care how well everything works in stock form, the engineer's best route is to "Over-engineer" products. Make things MORE than capable of how they are when things are "Right". Twin towers that can hopefully withstand a hit by a 747 for example....
Plastic endtanks on something (Radiator) that holds coolant, plastic AST tanks, a HIGHER degree thermoswitch,...ugh. Gee, this new Rx7 will have more power, 2 turbo's, and probably make more heat...lets make things plastic and let the fans wait even LONGER to come on than the FC! BRILLIANT!
Hope the one guy who had these awesome idea's was fired. I know they wanted weight savings as a mindset, but come on...
Nonetheless, thanks for an awesome find. BTW- 95c is 205f for those of you (LIKE ME!) that have Water Temp gauges that read in Fahrenheit.
PhoenixDownVII is offline
Old 02-20-05, 10:31 AM
Constant threat
bajaman's Avatar
Yikes! 115 C is 239 F for God's sake! My poor car!
bajaman is offline
Old 02-20-05, 10:32 AM
RX-7 Bad Ass
DaleClark's Avatar
The plastic AST was a bad idea. Plastic/aluminum radiators are actually prety nice - very efficient, less prone to corrosion, and light weight. The sad thing is plastic end tanks CAN be replaced, but there aren't many places in the US that can do that kind of work.
Also, the FC had a clutch-driven fan as its main cooling method. The electric fan was a VERY small fan (about 8-10") in front of the radiator and condenser that only ran if the car got hot enough (kicked on by the thermoswitch) or if the AC was on to increase air flow through the AC condenser.
Considering the FC ran relatively cool, it's still odd that the FD ran so hot. They may have needed to run the car hotter to get fuel economy to where they wanted so it wouldn't have been hit with the gas guzzler tax. It may be another thing, like the precat, that Mazda *had* to do to be able to sell the FD in the US.
But, the good thing is we can find solutions around the things Mazda had to do. That's the goal with my car - to make it into the car that Mazda wanted to build.
Dale
Old 02-20-05, 10:54 AM
KevinK2's Avatar
"However, I am perplexed as to why I have a 115 degree switch? Maybe because of the automatic tranny?"
This is a separate trans switch for autos, located where one of the plugs normally resides in the fill neck hsg. If coolant hits 240F, atx logic engages torque converter lock-up more often, to reduce heat from torque converter.
You still have 108C fan switch, behind t-stat. Replacing with FC-or-miata switch means, with ac off, fans come on 1st at 207F at med speed, vs 221F (ecu controlled) at slow speed then 226F at med speed. Note this may only change med speed trip to 221F for some.
Alternative is to run with parking lights on, or cabin fan at 3 or more, in hot traffic. This trips fans on slow at about 200-210F.
KevinK2 is offline
Old 02-20-05, 11:32 AM
Constant threat
bajaman's Avatar
Aha! That explains things. Yeah, I just found the normal thermoswitch...my God but that is a bitch to get to, and I have the engine out and half apart!
Thanks for the info!
(Though I feel a little stupid.....)
bajaman is offline
Quick Reply: FC thermoswitch for FD
