Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D Memory cartridges
Old Jul 25, 2005 | 08:42 PM
Rx4 whore's Avatar
Question Memory cartridges
does anyone know if the version 3 and 4 cartridges are cross compatible?
thanks
Old Jul 26, 2005 | 12:36 AM
signofinfinity's Avatar
Coyote
nope they arent.... at least my vers3 didnt work on my vers4.
Regards
Old Jul 26, 2005 | 06:24 AM
Rx4 whore's Avatar
thanks for that
thought i'd check
Old Jul 26, 2005 | 09:44 AM
Coyote
But i guess they can be built.....anyone got a component list for the build?
i would use the vers 3 housings for the cart and rebuild the components.....
anyone tried it yet?
Old Jul 27, 2005 | 03:34 AM
Rx4 whore's Avatar
Does anyone know or a suitable IC (eeprom?) that can be used in the memory cartridge for a version 3?
I have a number on the surface of the chip (OF963270) but cannot find any details on it for a replacement.
Thanks
Old Jul 27, 2005 | 06:23 PM
Chris Ng's Avatar
I'm with stupid -----^
I still have about 8 or 9 chips left over that I purchased to make my ver 3.1 cartridges.. they are 93c86an .. they are readily availible, but tough to buy in small quantities for a realistic price.. If you gusy are interested, let me know..
By the way, be careful with old cartridges.. my original cartridge developed a problem where it would still save maps, however, it would screw up random fuel/timing points and reduce them to 0... so I would save from the computer, insert the cartridge, save the map from the cartridge to wolf, then find that certain fuel/timing points were at 0 .. if I did not look through my maps manually on the handcontroller, I would have probably popped my motor ... I now makes sure I go through all my load points on the hand controller to make sure all my informatino has been loaded..
Chris
Old Jul 27, 2005 | 08:42 PM
Rx4 whore's Avatar
an update
the chip ID in my cartridge is
CSI - 93C86P - 97198
Old Jul 28, 2005 | 06:33 AM
Rx4 whore's Avatar
where can the enclosures that the memory catridges use be bought from?
Old Mar 15, 2010 | 05:28 AM
Rx4 whore's Avatar
Resurrecting this old thread....
I'm after details of the component that are used in the V4 memory cartridge. I've just purchased a V4 ecu without one & want to make myself one
Thanks in advance for any help.
Coochas
44
Nov 5, 2019 11:08 PM
zkeller
Dec 28, 2002 10:42 AM
RX7JW
Feb 10, 2002 12:33 AM
ScruffyChimp
Nov 16, 2001 02:56 PM
WorkS2R
Sep 11, 2001 02:43 AM
