Will 285/35/18x9.5 +35 and 245/40/18x8.5 +30 5Zigen FN01RC fit 93 FD?
Old Jul 22, 2005 | 05:30 PM
enigma9o7's Avatar
Newbie
Friend with an RX7 is interested in my stagger wheels/tire setup. Did a little searching and see a couple people running 275/35/18 or 295/30/18 but nothing exactly the same. Also the offset is a little different than what 5zigen reccommends for your cars (they say 18x8.5 + 38 and 18x9.4 +45), seems to me all that means is these wheels willstick out 8mm farther on the front and 1cm farther on the rear, which isn't too bad unless it looks bad... but maybe it'd rub the rear fenders? Front should be alright?
Thanks.
Old Jul 22, 2005 | 05:39 PM
tripleseis's Avatar
The wheels will fit depending on your style. The tires...dunno about that
Old Jul 22, 2005 | 06:57 PM
rynberg's Avatar
Those wheels will NOT fit with the stock fenders.... You would most likely have to cut the rear fender lip (not roll) to make the rears work. The fronts will stick out farther than running 285/30s up front....
And those tire sizes are wrong....they are a full inch too tall. Even if you massaged the fenders to fit, you would have to ditch the tires and get proper sizes (235/40 or 245/35 front, 265/35 or 275/35 rear).
Old Jul 22, 2005 | 11:07 PM
enigma9o7's Avatar
Newbie
Yep, gave them a test drive on my friends car. Front seemeed perfectly fine. The rear fender rubbed the outside of the rear tires on bumps, on the very outter edge of the tire. I imagine with bigger offset (+45 as 5zigen reccommends) or narrower tires (275/35 as suggested above) they would clear the fenders. Instead, he thinks he wants to find some widebody rear fenders to make these fit.
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
