Haltech What a/f is your idle
Old Jul 22, 2005 | 03:05 PM
raven bc's Avatar
Apex seal blower
Hey everyone I can't get my A/F down at idle. Currently it's around 12-13 any attempt to reduce the fuel leads to the car stalling out all the time. I have a ported motor and my idle is around 900-1000. I just thought I would try to find out what other people's A/F ratios are at idle.
Raven
Old Jul 22, 2005 | 09:22 PM
Carlos Iglesias's Avatar
Corn-to-Noise Converter
Veteran: Navy
Top Answer: 1
My street ported FD likes 12.5 -13.5 on a cold engine with ambient air temp <80F and about .5 leaner at ambient temps 80-100F. Once the engine is up to temp, I can easily run 1.0 richer.
Old Jul 22, 2005 | 11:37 PM
RETed's Avatar
That's NORMAL!
These engines like rich idles.
-Ted
Old Jul 23, 2005 | 04:27 AM
C. Ludwig's Avatar
www.lms-efi.com
Most all engines like rich idles. Rich being a term relative to stoich. The air speed is slow enough that fuel falls out of atomization and isn't burned properly.
Old Jul 24, 2005 | 12:24 AM
CyborgRyu's Avatar
Drift FC
14.5 is bad?
Old Jul 24, 2005 | 01:03 AM
RETed's Avatar
Originally Posted by CyborgRyu
14.5 is bad?
It just means your wide-band sensor needs to be changed.
-Ted
Old Jul 24, 2005 | 03:42 PM
Carl Byck's Avatar
Mad Man
12.5-13
Old Jul 24, 2005 | 05:05 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Idle on a rotary can be set sometimes anywhere between 13-14, but i have seen 13B turbo engines that dont even like part load at 13.5 AFR, and foul up.
Also, ambient conditions play an inportant part in that too.
13.0 should be fine for most conditions, runing the ilde in the 12's in traffic will probably fowl the plugs faster then usual.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
