Got FD Dyno today
Old Jul 21, 2005 | 04:27 PM
MR_Rick's Avatar
Planning my come back
Got FD Dyno today
Well I'm kind of disapointed. I made 294 whp @ 12 psi on a 101 degree day and the car temp was at 200. I know I need to do a tune up, so that might have played a part also. So it's that okay for the conditions the car was at? Mods are on sig.
Old Jul 21, 2005 | 04:31 PM
boostin13b's Avatar
That doesn't sound too bad to me. Especially on that hot of a day. I know here it's been 105+ degrees. On a dyno it's extremly hard to get the right amount of Air flow to your intercooler. Sounds like some decent numbers to me.
Old Jul 21, 2005 | 04:38 PM
MR_Rick's Avatar
oh and it was on a 3rd gear also which I just found out is the wrong gear on our cars
Old Jul 21, 2005 | 04:44 PM
Montego's Avatar
Don't worry be happy...
Top Answer: 1
yeah I also think that's really good considering the outside temps. I remember some posts that some people don't even drive their car past 90 degree F since the car looses quite a bit of umph and therefore no fun.
Old Jul 21, 2005 | 04:52 PM
bleung's Avatar
your power curve will look different between 3rd and 4th gear?
Old Jul 21, 2005 | 04:53 PM
Julian's Avatar
HaHaHa; that would give us in texas about 3 weeks a year to drive and two of those would be in heavy rain.
Old Jul 21, 2005 | 05:13 PM
Tim Benton's Avatar
FD title holder since 94
what was the correction factor on the run?
Tim
Old Jul 21, 2005 | 05:17 PM
Montego's Avatar
Top Answer: 1
wells sucks to be you then
Old Jul 21, 2005 | 05:19 PM
MR_Rick's Avatar
He didn't give me that. it was all SAE.
Old Jul 21, 2005 | 05:31 PM
Tim Benton's Avatar
well it helps to show how much over SAE standard conditions the run was tested in. Sounds like about a 1.04 or 1.05 (maybe higher). Anything in that range and the computer program is factoring in a lot so the data isn't as useful as a CF of 1.02 or 1.03.
He should be able to pull your run back up and see what it was.
Tim
JaNusSolSumnus's Avatar
TRINGLS
Where is the graph?! ...and those are nice numbers for the heat, wow.
I'm intrigued, I'm hoping for 300whp once I'm back on the road.
~Kris
Old Jul 21, 2005 | 05:33 PM
MR_Rick's Avatar
look at sig for mods trying to get the graph scanned or waiting on the guy to e-mail it to me
Old Jul 21, 2005 | 05:36 PM
MR_Rick's Avatar
Tim
Oh SAE was 1.02
Old Jul 21, 2005 | 06:17 PM
MR_Rick's Avatar
man I wish there was a way I could show you guys this graph because I think is all out of wack
Old Jul 21, 2005 | 06:19 PM
MR_Rick's Avatar
this is the best I can do for now
http://img239.imageshack.us/img239/5401/im0000771rj.jpg
the reason I say it has to be out of wack is because the torque curve and the a/f ration can't be that hi with the smell of gas there was on that place and the amount of black smoke that was coming out.
Old Jul 22, 2005 | 06:51 AM
cruiser's Avatar
AFRs in 13's ?
Old Jul 22, 2005 | 10:52 AM
MR_Rick's Avatar
I don't believe that since you can just see that it was running rich as hell
Old Jul 26, 2005 | 04:44 PM
2FAST7S's Avatar
Were you having the car tuned?
I'd be pretty happy with those numbers in that heat! I made close to that at the boost on a not as hot day so youre pretty much on track.
I'd worry about those afrs though...
Old Jul 28, 2005 | 07:51 AM
MR_Rick's Avatar
I have a Pettit ECU so no need for tunnig. I don't think my A/F is correct. You ever been around a old diesel tractor with all that smoke when it goes at WOT and it burn your eyes from the fuel? well that's how my car felt like through out that hole dyno run.
But that'sokay, here in about 3 month I be putting my GT35R with PFC and 850 and 1600 injectors
Old Aug 4, 2005 | 11:44 AM
2FAST7S's Avatar
Well, if you have a midpipe no matter how lean/rich you are, in an enclosed space even at idle your eyes will get irritated! Every single time i've had my car dynoed, i either walk out and watch from a distance or stand by the door.
All i'm saying is, if it were me i'd make sure.
That GT35R is pretty sweet! I know of at least 3 FDs with the 35/40 kit and they all make instant boost and tons of power. The one thing i've heard is that it is hard to tune otherwise great!
Old Aug 4, 2005 | 10:21 PM
1QWIK7's Avatar
White chicks > *
nice man, i have about the same mods as you..im hoping for somewhere near that hp range..i think the air temps def had something to do with it plus your tuneup maybe?
Old Aug 5, 2005 | 06:27 PM
moehler's Avatar
The horse power seems good for that heat, but the torque seems really low.
I made 294 rwhp and 264 ft-lbs @ 14 psi with intake temps at 65 deg (over 90 deg F ambient temp). This was with similar mods except an smic, cat, and tuned pfc.
Old Aug 12, 2005 | 05:39 PM
MR_Rick's Avatar
I was told that he was having trouble getting a RPM signal.
Coochas
44
Nov 5, 2019 11:08 PM
Rotate86
May 18, 2018 02:44 PM
Andrew7dg
Aug 6, 2017 01:41 PM
RX200013B
Haltech Forum
Oct 12, 2015 09:45 PM
Sh00bs
Oct 1, 2015 11:57 PM
