can a PP13b single turbo make 1000hp?
Old Jul 4, 2005 | 06:18 PM
Bluem's Avatar
Concept Motorsports
could a PP 13b with a huge turbo like gt42r or a HKS t-51 on methanol make 1000hp???
Old Jul 4, 2005 | 06:20 PM
BlaCkPlaGUE's Avatar
I live in an igloo
I highly doubt it. Well, not reliably at all I would think. Obviously im not an expert, so we'll wait for others to chime in.
To give you an idea, I saw a 20B PP single turbo in turbo and high tech performance, it was making like around 1000hp as far as I remember. I really think you need that extra 3rd rotor.
Old Jul 4, 2005 | 06:23 PM
Bluem's Avatar
Concept Motorsports
here theres a new 3-rotor pp single turbo pushing about 1,300hp
Old Jul 4, 2005 | 08:38 PM
KNONFS's Avatar
B O R I C U A
Which one, Confinado?
Last I heard about PP + turbo, was that it is an extremely hard combination to tune, some people say it not worth it.
Old Jul 4, 2005 | 09:58 PM
RX7WEEE's Avatar
Need a 20b FD.
3-Rotor Race Engine
Racing Beat currently has available for sale a very rare Peripherally Ported, Mazda Race 13G 3-Rotor engine in Racing Beat-engineered, single turbocharger configuration.
The engine is a complete Racing Beat built package producing more than 1000 bhp at 8500 RPM with approximately 21 pounds of boost. Designed to run on methanol, thereby eliminating the need for an intercooler, the race engine package incorporates an EFI Systems Engine Management System supported by a Kinsler Fuel Injection gear-rotor mechanical fuel injection pump. As prepared by Racing Beat, the engine features a complete Peterson Fluid Systems 4-stage oil scavenging assembly. Additionally, the engine utilizes an HPD water pump mounted to a Racing Beat-designed, cast aluminum front cover. These race-proven Kinsler, Peterson, and HPD components are all Gilmer belt-driven peripherals. The turbo charger selected for thes package is the AirResearch T18A90 series with the M-4 compressor wheel. As equipped by Racing Beat, the turbocharger features a TIAL Waste Gate modified to minimize boost spikes.
Internally, the engine includes the following features:
- All tension bolts fully "pinned"
- Water jacket modification on all rotor housings
- Iannetti Ceramic Apex Seals 3mm
- 7.5 to 1 Low-compression ratio rotors, cast by Mazda Japan
- Exhaust manifold - Inconel 625, including all bellows.
For more information or specifications, contact Racing Beat and ask for Jim Tanner at 714-779-8677.
Only $48,000 from racingbeat.
Old Jul 4, 2005 | 11:01 PM
Maxthe7man's Avatar
Freedoms worth a buck o'5
^^^ That is rather tasty looking..
But kinda deflates when you consider AFR has a street driven fd with 850 rwhp on a 13b pport T51 . You would think all that hardware on the 13g would add up to more hp than that..Not to beat up on racing beat, but their project motors hp always seems a little low for all that exotic hardware and budget involved..Max
Old Jul 5, 2005 | 02:06 AM
I live in an igloo
I would think that the difference between AFR's engine and racing beats engine regardless of cost would be a much longer reliability maybe? not to sure, don't flame me
Old Jul 5, 2005 | 07:09 AM
Maxthe7man's Avatar
ARF's is plated and street driven, told us he commutes to work in it when hes not dragging it..
Old Jul 5, 2005 | 11:20 AM
Zero R's Avatar
Just in time to die
People have made 1000hp on two rotors, just not too sure about rear wheel.
Old Jul 5, 2005 | 11:21 AM
powrdby13B's Avatar
i'll blow YOUR valve off
so the general rule would be that yes it's possible, but if you don't know exactly what you're doing it's going to be a poor idea.
Old Jul 5, 2005 | 03:54 PM
crispeed's Avatar
'Tuna'
I've seen some dynos in the mid to high 800 rwhp.
Ken Schepers Rx-8 made high 800's on a Mustang dyno and 940 rwhp on a Dynojet and that's with a side port 13b motor.
Old Jul 5, 2005 | 04:33 PM
Bluem's Avatar
Concept Motorsports
imagine a custom pp 4-rotor with dual gt-42r or t-51!
Old Jul 5, 2005 | 04:34 PM
t-von's Avatar
Rotor Head Extreme
Side port! Damn how much boost did that take to make that much?
Old Jul 5, 2005 | 04:45 PM
crispeed's Avatar
'Tuna'
42 to 44psi!
Old Jul 5, 2005 | 06:06 PM
rx72c's Avatar
Top Answer: 1
1000hp isnt impossible.
But the gt42r and the t51r are too small.
Two gt35rs on a pp 13b will make 1000hp or come very close to it.
Old Jul 5, 2005 | 06:48 PM
Marcel Burkett's Avatar
How much would I make with a semi-pp 13B a, Jaytech intake equipped and twin GT3071R's ?
Old Jul 5, 2005 | 07:00 PM
rx72c's Avatar
Top Answer: 1
Which jaytech do you have.
No one can tell you exactly but on around 30psi 700hp is possible. your turbos are fairly small.
Old Jul 5, 2005 | 09:29 PM
I have the Holley styled ,5" 4 injector throttle body and the semi pp Cosmo manifold . "Fairly small" ? , each one flows 490lbs/ min , thats nough for 490 hp !
Old Jul 5, 2005 | 10:43 PM
rx72c's Avatar
Top Answer: 1
490hp.. Um no.
They are not big turbos.
Anyway.
you will make 600rwhp. On 30psi i think.
Old Jul 5, 2005 | 11:33 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
not on a rotary though.
Old Jul 5, 2005 | 11:39 PM
600 whp is more than enough for me !!
Old Jul 6, 2005 | 12:32 AM
enzo250's Avatar
IRS Champion
Very Well Said... People don't realize what it takes to make serious power.
GT42 although looks big, it wont' make that kind of power(on a rotary)..
Good turbo for a street car though..
Two GT35 would do it but 1000hp at the rear wheels is not easy to make with two rotors but not impossible!!! 950 is the most i've ever heard of.
that's 475hp per rotor!!! That's Serious!
I'm sure someone will figure out how to get 500 per rotor.
I think PP Turbo w/ meth is the way to do it...
Old Jul 6, 2005 | 08:18 AM
turboR1's Avatar
ErnieTKiLLA
WOW gt42 on a street car... that must be like cruising around town in a shifter kart
Old Jul 6, 2005 | 09:37 AM
speedx7's Avatar
Rotors keep you going
that would be somrething else
sherff
Feb 24, 2019 12:09 PM
