Highest Hp Single turbo
Old Jun 25, 2005 | 07:18 PM
BlaCkPlaGUE's Avatar
I live in an igloo
Just curious, but whats the highest Hp single turbo you guys have seen on this site for any of the 13B, 13BREW, 13BRE, or 20B engines?
I saw the 20B in turbo in high tech performance in the RX8 shell I believe doing about 1000hp.
What im trying to get to, is whats the limit that these engines can produce? or have produced?
Is it even possible to get like 1500hp or higher? lol
Old Jun 27, 2005 | 07:18 PM
darkphantom's Avatar
The king of the highway!
710 on a t51R
Old Jun 27, 2005 | 07:21 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
search nopistons.com's engine building section
1800hp, 4 rotor, 2hks 51kia's and alot of methy, highest i have seen personaly is high 500's, runs a 9sec 1/4
Old Jun 27, 2005 | 07:54 PM
ErnieT's Avatar
Living life 9 seconds at a time
Ray Wilson made 650ish to the wheels on C116.
Dee made 776rwhp on a mix of alcohol and C116.
Old Jun 27, 2005 | 08:26 PM
and someone on here (has dyno) made 648 @27lbs
and that t51 was on @2.0 bar
Ernie whats a C116??
Old Jun 27, 2005 | 08:32 PM
kabooski's Avatar
Laying Down Rotary Law
Lets see some sheets
Old Jun 27, 2005 | 08:36 PM
APEXL8T's Avatar
boxed in and drawn out
damn....
Kabooski hows your motor doing? I was excited for you...I would like to do that with mine.
Old Jun 27, 2005 | 08:41 PM
kabooski's Avatar
Originally Posted by APEXL8T
damn....
(not my sheet above..lol)
Motor is doing great!
unfortunately
My PT-67
is starting to fail
wheel is catching on the inlet
doesnt spool like it use to
add my HKS wastegate
is sticking
planning
a diffrent combo now
to hit over 600 HP
Old Jun 27, 2005 | 09:12 PM
T04Eneedy's Avatar
adiabaticly inefficient
Wink
unfortunately
My PT-67
is starting to fail
is sticking
planning
to hit over 600 HP
wow what turbo do u plan on goin to?or is it top secret?
Old Jun 27, 2005 | 09:33 PM
kabooski's Avatar
Next project is:
cat Turbo
with a LONG tubular manifold
4" DP/Exhaust
CLR rotors (if I open the engine again)
Switching from the NPR larger intercooler (skinny, but flows good)
to a Monster that flows and cools better
and of course lots more fuel
I need race axles
as it is now..hehe
Attached Thumbnails Highest Hp Single turbo-picture-107892261.jpg   Highest Hp Single turbo-picture-107892266.jpg   Highest Hp Single turbo-picture-107892263.jpg
Old Jun 28, 2005 | 05:48 AM
APEXL8T's Avatar
Next project is:
cat Turbo
4" DP/Exhaust
I need race axles
as it is now..hehe
damnnn. I happen to get the TO4r(67) myself with a 1.00 dived. I was wondering about the axles.....was that a lot of hit on streets or track tires? And you want more turbo?
Old Jun 28, 2005 | 06:04 AM
kabooski's Avatar
I need more top end
which only a bigger rear A/R like your 1.00 could give
Instead of me
dishing out the money for a new rear housing
and rebuild
I rather just upgrade to a New bigger turbo
and put the T67 on my other T2
With ET streets
I did numrous
1.48-1.49 60' foots
I tried using Drag Radials
this past Friday
and this happned in my 1st attempt
revved the motor
to 5k
let the hammer drop
car squated then "clunk"
Drag Radials just dont absorb the shock
Like ET streets do
Old Jun 28, 2005 | 06:29 AM
LUPE's Avatar
I need more top end
Instead of me
and rebuild
With ET streets
I did numrous
1.48-1.49 60' foots
this past Friday
revved the motor
to 5k
let the hammer drop
Like ET streets do
how are you launching so hard? Bottle?
Old Jun 28, 2005 | 06:33 AM
KNONFS's Avatar
B O R I C U A
Next project is:
cat Turbo
4" DP/Exhaust
I need race axles
as it is now..hehe
Hey man,
Do you have any pics of the intercooler piping on your car? I will be using the small NPR intercooler, but I am not sure how to set up the piping
Old Jun 28, 2005 | 09:20 PM
silvr94r2's Avatar
I need more top end
Instead of me
and rebuild
With ET streets
I did numrous
1.48-1.49 60' foots
this past Friday
revved the motor
to 5k
let the hammer drop
Like ET streets do
Which drag radials do you have? I take it you don't have much for sidewall? What was your tire pressure at? We've had really good look with drag radials but they are a little tricky. You either have to add more air so they'll spin a little or ride the clutch out a little so it doesn't shock. I'm sure you know these things so i hope i don't offend you.
We do have auto's in most of the Supra's that we run but quite a few of them are 6spd. Did i just say Supra on a RX7 site? OOps!
I'm helping a guy right now with a 2nd gen Rx7 so we'll see exactly how it reacts to the drag radial. We're gonna be running the 275 50 15 M/T drag radial. Hit it the 1st couple of times with 17-18 lbs. of air and start dropping from there. Don't usually like to go below 13-14 on a drag radial....at least in our experience.
Old Jun 28, 2005 | 09:28 PM
kabooski's Avatar
I had the Air at 17 PSI
I have run this same drag radials
before
BFG 255/50/16
I have always slipped the clutch with them
But since I had good results dumping the clutch with the et streets
(spin then grab)
I thought I would try it
with the Drag Radials
Lets just say
It did not spin
It got major traction
They just layed some fresh VHT...lol
I won't try that again
till I get some chromoly axles
Old Jun 30, 2005 | 08:26 AM
rotor_dee's Avatar
Correction Erniet Back in 2003
769rwhp c116 turbo only no NOS
http://www.reactiveracing.com/module...b9fd32a110aae7
On methonal don't know never had it on a dyno.
Kabooski very nice torque numbers !!
Old Jun 30, 2005 | 08:45 AM
kabooski's Avatar
actually thats Ari yallon's dyno sheet
But he posted that it migh be off since his clutch was slipping it might of gave inflated hp/torque numbers
He does not know for sure
either way
at 5K is where the Nos kicks in in the sheet
But he does run low 9's
with those numbers with NoS he has to be close to it
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
