Haltech New E6X UPDATE! - Internal MAP Sensor
Old Jun 22, 2005 | 06:44 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Hello all, im happy to anounce that the latest versions of the E6X have a built in 2.5 bar map sensor that is capable of reading upto 22psi. This means an even greater reduction in initial costs. You can always use any exteral map sensor available, 1, 2, 3, 3.5, 4 and 5 bar versions, all you do is select it in the software.
I will update the price on my offer in the for sale section i have here.
https://www.rx7club.com/showthread.php?t=436001
Old Jun 23, 2005 | 12:41 AM
Wankel7's Avatar
Haven't we ALL heard this
So, does that mean you run a vacuum hose to the computer?
Old Jun 23, 2005 | 05:00 AM
EFI Tech Wannabe
Yes it does. It has a vacccum fitting on the side of the ECU opposite the connector.
Old Jun 23, 2005 | 05:04 AM
Wankel7's Avatar
Intresting.......so hose length dosen't affect the sensor reading?
James
Old Jun 23, 2005 | 05:25 AM
EFI Tech Wannabe
Haltech advises that the hose be as short and as close as possible to the map sensor, but microtech uses this internal styled map sensor on their ECUs, haltech used to have these on the F3 and F7, even some factory ECU's used to have this, so im guessing response time should be virtually the same, specially if you have a dedicated inlet for the map sensor along and a good hose.
Old Jun 23, 2005 | 01:20 PM
Syonyk's Avatar
If anything, I'd think the longer hose would help damp some of the vacuum pulsation. The stock pressure sensor line (FCs, I assume FDs are the same) has a restrictor pill in it to help reduce some of the pulsation. Running without this pill leads to drivability problems. A longer vacuum line would, I would think, have largely the same effect.
-=Russ=-
Old Jun 23, 2005 | 10:12 PM
sleeperfc's Avatar
MP T-70 = Fun
so how do we know if the e6x we are going to get has this?
Old Jun 23, 2005 | 11:46 PM
eViLRotor's Avatar
Brother of the Rotary
My Wolf3D had an intermal MAP sensor as well.
No problem with running a vac line into the car to the ECU.
Old Jun 25, 2005 | 06:39 PM
EFI Tech Wannabe
I called up Haltech on friday, and all current production of E6X is coming with the internal map sensor. All that are ordered will have it.
Old Jun 26, 2005 | 01:37 PM
Sesshoumaru's Avatar
Tenseiga
I have the internal map and I just recently ordered it from claudio.
I like this better than an external unit.
jsesq
27
Sep 25, 2015 11:10 AM
mulcryant
Sep 9, 2015 05:24 PM
befarrer
Sep 4, 2015 08:26 PM
