Cleaning up the rats nest...
Old Jan 7, 2002 | 01:08 AM
wonder1and's Avatar
I Sold My Car 2 the Devil
Question Cleaning up the rats nest...
I was wondering... I'm running the T04S setup and when I get my car back I would like to clean up the rats nest under my intake manifold and switch to silicone lines. I know that some of the Vacuum lines have been become useless in their presence. Have any of ya'll preformed this procedure or know of a good info site that could help me out???
Thanks for any input,
Ryker
Old Jan 7, 2002 | 11:07 PM
richjackson7's Avatar
i have been asking for weeks now and still no one cn help
Old Jan 8, 2002 | 12:06 AM
SPOautos's Avatar
Hey, where did my $$$ go?
As far as I know if your running single turbo the only vacume line you should have is for the fuel regulator.
What vacume lines are you talking about?
Old Jan 8, 2002 | 12:40 AM
wonder1and's Avatar
Well there is the large grouping of now hard and crusty rubber vacuum hoses that sit behind the alternator and below the intake manifold and to the left of the throttle body... any ideas??
Thanks,
Ryker
Old Jan 8, 2002 | 06:47 PM
Chris Wilson's Avatar
I am no rotary expert but my 3rd gen is having a TO4E fitted (by myself). I have removed all solenoids and hoses. All I have is a line to the fuel pressure regulator. I also have a line to the external wastegate via an aftermarket boost control solenoid. The kit is basd on the HKS one, the Japanese instructions detail some vac line removal, but I fail to see what else is required. I have long since removed secondary throttle control and hot start fuel pressure raise stuff. Other emissions stuff has also long been removed. It is one HELL of a lot cleaner install with the "rats nest" removed, and hopefully more reliable and easier to troubleshoot! Only other line is to the boost gauge.
Old Jan 8, 2002 | 08:44 PM
thanks.
i guess i have to get a kit for the cool instructions....
Old Jan 8, 2002 | 09:42 PM
RotaryKnight's Avatar
Same here I have the XS T04S kit also and all i have is like 3 lines under the manifold now.
Old Jan 8, 2002 | 10:19 PM
JBC's Avatar
JBC
You should have gotten those removed.
Old Jan 9, 2002 | 09:58 AM
Bacon's Avatar
IRS 4 Life
to remain emissions legal youll need to keep you acv lines and unit in tack, asside from that
1 for fpr- if u have single u prob should have rrfpr
1 to map sensor
1 to boost gauge
for the boost controller it should be routhed to a non vac boost source..ie right after the compressor housing..
not on the uim or lim......
then the 2 omp oil injectors u can either cap them or t' the tops of them together and run it to a nipple in the turbo inlet area
Old Jan 12, 2002 | 01:28 AM
TurboInside's Avatar
Better Than You
Last page, last line of instructions for to4e setup:
IC pipe to oil injection vacuum line "T" into injector air bleed socket.
Just reading it over before installation "What Is It"
Old Jan 22, 2002 | 02:44 PM
R-magic's Avatar
Smile post pics
Can someone post pics of what it looks like with everything that needs to be removed and what is left. This would really help. I will be removing my rats nest on Friday. Thanks!!
Old Jan 22, 2002 | 02:54 PM
0piston's Avatar
quick question?
With all the nipples left... do you just cap them all or leave them alone?
thanks!!
Old Jan 22, 2002 | 05:12 PM
i really need this info also PLEASE help me.....
Old Jan 22, 2002 | 07:15 PM
Heath's Avatar
MAGNUM SE7EN
We all need to know! Do we need a block off plate kit too?
Old Jan 23, 2002 | 08:28 AM
Dragon's Avatar
20B N/A Wide Body FC3S
Ok you Remove the upper intake manifold and remove all the hoses... all of them, but leave the solinoid rack, If your running a power FC you can take out all the solinoids too because the power FC will just ignore that they are gone... now run a vaccume line from the manifold to the fuel pressure regulator, and anouther to the MAP sensor, if your using a blow off, boost gauge etc run hoses to them too... while you have the upper manifold off rip out the actuator and throttle plates on the secondary runners and block off the hole by threading in a bolt or having the hole welded shut.. while your at it bypass the water line to the throttle body, just put a cap on the rear housing where the water comes out and one more on the front water pump housing where the water goes back in... If you want to remove the ugly emissons air pump thing on the inside of the lower manifold go to K2RD and buy the $10 block off plate... also take off 2 of the filters from some of the solinoids and put them on top of each of the 2 oil injectors just to keep dirt out... that's about as simple as I can make it...
Chris
Old Jan 24, 2002 | 11:08 AM
scott(pittsburgh)'s Avatar
where is the map sensor?
Old Jan 24, 2002 | 12:11 PM
wonder1and's Avatar
Look next to your intake elbow, its mounted on the car. Its about the size of a match book with MAZDA on it and its about half way between the elbow and your driver windshield wiper.... Has a hose connected to it.
Ryker
Old Jan 25, 2002 | 10:08 AM
ok, i thought that was a boost sensor?
do you still need it when going single with no emissions ?
Old Jan 25, 2002 | 10:44 AM
Dragon's Avatar
Boost sensor/MAP sensor are the same thing... And Yes if you want your car to run you will most definitly need it...
Old Feb 3, 2002 | 01:50 PM
any one have pics i just ordered my block off plate kit and hope to have some up soon
Old Feb 3, 2002 | 11:44 PM
wonder1and's Avatar
If your speaking of the block off plate needed for under the manifold any pics of this and hose re-vamping would be greatly appreciated.
Ryker
Old Feb 4, 2002 | 12:43 AM
spyfish007's Avatar
Yellow Dragon is no more
richjackson7: Just so you know .... the plates are coming from me. I'll try to get them out tomorrow. I need to upgrade the instructions so you don't get confused!
there are some pictures already floating around the forum and net. I'll get some new ones up soon.
Old Feb 5, 2002 | 12:09 PM
carcrazy's Avatar
Here ya go!
You are able to remove all the solenoids under the manifold with the aftermarket computer like the PFC. The only vacuum lines you require are the obvious lines like the ones to the oil bypass valves near the injectors as well as the other obvious ones like the PVC valve, boost controller, and blow-off vavle. All the original vacuum lines that control specifically your boost can be removed.
Basically follow the instructions for the boost controller as well as the blow-off valve. The will result in eliminating your "rats nest".
I believe I have some good pics on my web page. Click the www icon on this message.
regards
Rick
1993 RX-7
Old Feb 5, 2002 | 12:53 PM
wonder1and's Avatar
If I can get any pics that would be most helpful... even if it is a crappy one so I have some sort of idea of what I'm looking at... My instructions for my T04S setup didn't come back to me from RP when they installed it. I just prefer to have some sort of Idea of what I am looking at before I take the manifold off. carcrazys site dosn't have any good pics (of what were trying to find plent of other good ones though )just a partial shot of under the manifold.
Old Feb 5, 2002 | 07:42 PM
great i already took off the double throttle one and any extra instructions would be a great help... i am just tring to get as much info as i can for my web site i am putting up.... i am currently tring to get sponsered.
