Power FC is it worth it 550's or 850's
Old Jun 16, 2005 | 05:03 AM
quick_spoolin's Avatar
I'm Single..Turbo that is
Exclamation is it worth it 550's or 850's
Is it worth it to run 850's and 1200" or just go 550's and 1200's if your only running 16psi? i know the 850 primaries are almost impossible to get perfectly tune at the low end but will the 550's be enough for that much boost, and if so will they take 18psi?
Old Jun 16, 2005 | 01:57 PM
CANRX7GX's Avatar
PREDATOR
What mods are you planning on doing??? it would also depend alot on that
Old Jun 16, 2005 | 02:47 PM
AgentSpeed's Avatar
BNR built motor and twins
I run 550's and 1300's @ 15psi. I see 85% duty cycles at full boost.
Old Jun 16, 2005 | 02:59 PM
single turbo, i have a after market fuel pump, hks twin power, power fc obviously, ported motor, then the basic bolt ons.
Old Jun 16, 2005 | 05:32 PM
cewrx7r1's Avatar
Eye In The Sky
I am running 550/1200, GT35R, stock ports, Nippo improved pump, running 85% duty cycle at 15psi boost in summer, closer to 90% in winter.
I am on the edge, and need bigger injectors..
Old Jun 16, 2005 | 08:35 PM
what kind of hp numbers are you getting with that setup?
Old Jun 17, 2005 | 12:21 AM
cewrx7r1's Avatar
Eye In The Sky
Only one "bad" trip to the dyno since going single. Bad breaking up above 5000 rpm. Discovered that my Crane HI-6R went bad after 6 years use. Only made 352RWHP at 15psi that day. Have not gone back since. Have changed to different plugs and added a different ignition amplifier. Power should be about 385RWHP.
Old Jun 17, 2005 | 12:24 AM
i could live with that, i put down 320 to the wheels on my stock ported motor and 12psi so 385 would be killer
Old Jun 17, 2005 | 12:26 AM
i was running the 850's but i think after this and what i have heard about the tunning issues imma switch back to the 550's
Old Jun 17, 2005 | 01:13 AM
AgentSpeed's Avatar
385 is just right, that's what I made back in Jan.
Old Jun 17, 2005 | 04:22 PM
have you ran the track at 385hp?
Old Jun 17, 2005 | 05:18 PM
AgentSpeed's Avatar
I haven't, I don't know about Chuck. At Deal's Gap it was awesome though. I was very pleased with the power. The road race tires I have help...
WyomingTII
May 31, 2018 09:00 AM
93FD510
Oct 1, 2015 02:00 PM
