Power FC Tuning idle with 850cc primaries
Old Jun 8, 2005 | 12:39 PM
JhnRx7's Avatar
Golf Cart Hooligan
The past few days i have been tuning my car w/ the datalogit. I have no problems tuning WOT and acceleration while crusing, but when i try to tune a constant speed (P4, N5 N6 N7) and idle no matter how much i take out i cant get the A/F to go below 11.0. I searched a bit and i found some information leading me to believe that it is my 850cc primaries (i have 850cc primaries and 850cc secondaries). can anyone help me out w/ some settings to help me out.
Old Jun 8, 2005 | 12:43 PM
CrispyRX7's Avatar
Polishing Fiend
Do you have O2 feedback turned *off* when you are logging AFR's?
Crispy
Old Jun 8, 2005 | 12:45 PM
JhnRx7's Avatar
Golf Cart Hooligan
yep
Old Jun 8, 2005 | 04:25 PM
cewrx7r1's Avatar
Eye In The Sky
On Datalogit SETTINGS 5 where the injectors are set up, use a negative value for the 850 primaries lag, this will lean it out. The PFC/DL tries to prevent you from entering direct small injector times for the idle and cruise areas.
This is what others have tried.
Old Jun 8, 2005 | 07:43 PM
JhnRx7's Avatar
Golf Cart Hooligan
i was just about to try this... i found in another post that some people have put 80% and -0.04 lag. i will try this and see if it helps.
Old Jun 8, 2005 | 08:25 PM
JhnRx7's Avatar
Golf Cart Hooligan
alright i just tried tuning the idle down with the 80% -0.04 lag setting and it did not help, i still cant take fuel out of idle or cruse.
Old Jan 17, 2006 | 08:39 AM
M104-AMG's Avatar
Did you ever get this resolved ?
If so, how/what did you do ?
TIA,
:-) neil
Old Jan 17, 2006 | 01:33 PM
rotorbrain's Avatar
fart on a friends head!!!
i had ill effects trying to use the negative number in lag timing.
i think it just happens to have something to do with the dynamics of the injector not working well with the dynamics of its manifold entry point.
i have had the port that runs to the primary injectors plugged all this time, and have wondered if that has something to do with the poor atomization. ive wanted to hook it back up, but i just dont know what that port needs to see in order to work properly.
any insight on that?
Old Jan 17, 2006 | 02:07 PM
twin snails's Avatar
Im not sure what port you have blocked off, but for lag times, you need to go lower than -0.04 to get it to run right. You will have problems with it running lean and bucking in other low pressure areas of the map, so you will need to retune everything after you play with the settings.
For 850’s I am running -0.53 lag, and have the injector % set to 80%. I can get it to idle down to 13.5 AFR no problems.
Old Jan 23, 2006 | 10:21 PM
SlvrRexx's Avatar
umm.... this may be stupid but I know i did this. Is ur wideband connected correctly and programmed? I hooked mine up at first but i never programmed it so it seemed like i was tuning at WOT but i was doing nothin but playing with fire...... good thing i was only adding fuel but yeh ..... check that. thats my input.
DerpyToast
14
Nov 23, 2024 05:19 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
83revival
Sep 3, 2015 10:42 PM
