NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
Summit Point Time Trial
Old Jun 3, 2005 | 07:44 PM
RX-Midget's Avatar
I'm not a Midget!
Last weekend was the first time i had run the Spring Jefferson Time Trial put on by the NEPA region of the SCCA. What a blast! I had only run the jefferson circuit in a counter-clockwise direction before, but they run it clockwise in the spring, and CCW in the fall.
If you guys want to com out and run a time trial, check out the PA Hillclimb assoc. web site:
http://www.pahillclimb.org/Schedule.htm
The fall event is Sept 3-4.
http://www.pahillclimb.org/Courses/Jefferson.htm
Attached Thumbnails Summit Point Time Trial-drifting-turn-1.jpg   Summit Point Time Trial-down-front-straight.jpg   Summit Point Time Trial-rookie-stripes.jpg
Old Jun 3, 2005 | 09:27 PM
sudseh's Avatar
Attack Gas Station!!!!
how well did you do?
I'd be very interested in taking my van when I finish it, but I don't know exactly what sort of safety stuff I'd need.
Old Jun 4, 2005 | 09:02 PM
RX-Midget's Avatar
I'm not a Midget!
2nd in S-2 class. That class is pretty much anthing goes from 1651cc - 3500cc (rotarys get classed at 2x their rated displacement ) This mean that I run against purpose built tube frame cars on slicks that never run on the road.
First place went to a Porshe 914-6 that is a dedicated track only car with wide flares and slicks. I was only 0.2 sec behind him and I'm running DOT tires and I'm street legal (mostly!). I've run 61.xxx on that track when my tires were 3 years younger(unofficial since it was with NASA) , so with some new tires I shoud have no problem beating him and setting a class record (61.xxx sec) this fall.
Check out the site I lised above for safty info, but you will need a 2 layer nomex suit, gloves, socks, fire extingusher or system, SA95 or new helmet. You will need to check the GCR for roll bar/cage requirements. I'm not sure they will let the van run - they get picky about things with high centers of gravity, but send them an e-mail to see.
Jan 11, 2016 04:08 PM
82streetracer
Aug 23, 2015 09:28 AM
Aug 21, 2015 08:35 PM
smikels
Aug 18, 2015 01:26 PM
