Come On Guys Serious Help is Needed!!!
Old Jan 4, 2002 | 10:56 PM
VIPERKILLER's Avatar
I've posted numerous times about this and I need serious help......I need to know what Turbo to use on a 13B.....I want to achieve 500+rwhp and want it for street/strip at least mid 10's. I like the T100 but don't think it'll spool....what other turbos are there? PLEASE SOMEONE ANSWER AND HELP!!!!!!!!!!
Old Jan 4, 2002 | 11:19 PM
rx7passion's Avatar
get a t-76, t-72 you should be well over 500+ rwhp. crispeed uses a t-72 i believe and he does low 9s
Old Jan 4, 2002 | 11:30 PM
What is the price on a T76 or T72......and are they better than a T88?
Old Jan 5, 2002 | 01:08 AM
wonder1and's Avatar
I Sold My Car 2 the Devil
Hey is this a race only car? If not, make sure to dump plenty of $ into fuel and ignition mods before going into the land of the dead rotor. Also when you want to make this 500+ hp what kind of porting will have been done to the motor?
Ryker
Old Jan 5, 2002 | 01:19 AM
MeLoco's Avatar
There are way more things invovled than just 500rwhp to get to mid 10's but it helps Is this car more for street or strip? Is it ported? what type of fuel system do you have?There are alot of options, just try and be a little more specific.
Old Jan 5, 2002 | 07:43 PM
I won't be porting now.....I figure during the tuning we "might" blow the motor and if we do then we will port it?!?!?! Is that correct? What kind of fuel system do you guys recommend?
Old Jan 5, 2002 | 07:58 PM
Jedon's Avatar
Slave2TheFD
fuel pump (bosch, walbro,denso etc)
injectors (bored 850,1300 or 500 + 1600 with modified rail)
fuel pressure regulator (sx)
max cooper has a fuel requirement calculator, look around for it.
Old Jan 5, 2002 | 08:40 PM
rx7passion's Avatar
*edit* cause i dont know wtf im talking about
Old Jan 5, 2002 | 10:16 PM
MeLoco's Avatar
Just in case, Jedon is saying 850 primaries/1300 secondaries or 500 primaries/1600 secondaries.Why would you plan on blowing it up?, that doesn't sound to confidence inspiring to me. I do think you are going to have a hard time getting 500+rwhp on a nonported motor.
Old Jan 6, 2002 | 09:40 PM
ErnieT's Avatar
Living life 9 seconds at a time
My setup....
Clacor
Aug 14, 2015 09:17 AM
