clutch recomendation
Old May 21, 2005 | 04:00 PM
chrislaw1968's Avatar
hi
what clutch do you guys recomend to run with single turbo (HKS TO4-R) at a reasonable price , taking into account i will need to have it shipped to the uk.
regards
chris
Old May 21, 2005 | 04:28 PM
sillbeer's Avatar
Os giken twin plate.
-Destin
Old May 31, 2005 | 06:47 PM
suprfast's Avatar
im a huge clutchmasters fan, but i havent heard of many using the CM on the rx7's. They also make full twin plate setups
kris
Old May 31, 2005 | 07:16 PM
MakoRacing's Avatar
Where has my $ gone?
Exedy hyper single or twin plate
Old Jun 1, 2005 | 12:31 AM
rx7tt95's Avatar
Photo Diety
Vote two for the Exedy Hyper single. It'll hold 500hp no issues. Initially a bit tough to get used to driving around town but as it breaks in it gets better. Allows for shifts that take half the time compared to an ACT Extreme street/strip. Very crisp.
Old Jun 1, 2005 | 02:35 AM
maxcooper's Avatar
WWFSMD
I am liking my Exedy Hyper Single, too. It was a bit hard to get used to at first, but I am used to it now and it's no problem on the street. I think it has gotten easier to drive through the break-in, too. You can't slip it much or it will chatter, but that isn't much of a problem. The engagement is satisfyingly crisp. I feel confident that it is not slipping, unlike my old clutch which I suspected would slip at full boost.
-Max
Old Jun 1, 2005 | 04:39 PM
Nihilanthic's Avatar
moon ******
If you cant slip it when you start off, how do you without chirping your tires?
Sorry to ask, but I havent had any experience with clutches like that (except new 'regular' ones which slip a little anyay.
Old Jun 1, 2005 | 06:30 PM
maxcooper's Avatar
WWFSMD
It does slip a little, and it also has a sprung hub. But it would be a bad idea to sit on a hill and try to hold yourself in place by slipping the clutch. When you start moving from a stop in normal driving, you just engage and go at an RPM/power level that isn't going to chirp the tires.
-Max
Old Jun 1, 2005 | 06:46 PM
moon ******
AAaahhh.... Thanks max!
Old Jun 1, 2005 | 07:38 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
vote three for the exedy hyper single.
i have 3000 miles on it and love it. it is built like a double disc so it is unlike other resprung OEM clutches. do a search for info.
howard coleman
Old Jun 2, 2005 | 02:59 PM
Carl Byck's Avatar
Mad Man
Except for the fact that it sounds like he is on a budget, I agree. On a budget, I am going to try the sprung six puck Spec Clutch. ~350.00 with a clutch tool, and both bearings. Carl
Old Jun 2, 2005 | 05:09 PM
i have seen some XTD six puck clutches on ebay for just over $350 , has anyone used these clutches and are they any good.
regards
chris
Old Jun 7, 2005 | 03:37 PM
MattGold's Avatar
Form > Function
regards
chris
I do *NOT* recommend these.
They are a cheap rip off of a quality part. They are more or less using our name (something that sounds like our name) and selling CRAP.
As for a good setup for the FD, I highly recommend the Twin Metallic, a *true* street clutch with smooth engagement.
If you are on a budget, try our "Stage 2", it's a 3-puck *sprung* hub complete with P.Plate, disc and all bearings.
Old Jun 8, 2005 | 12:12 AM
fastrotaries's Avatar
W. TX chirpin Monkey
who are you? and who is us?
Old Jun 8, 2005 | 01:18 AM
maxcooper's Avatar
WWFSMD
MattGold is from Exedy.
-Max
Old Jun 8, 2005 | 11:06 AM
Rx7thHeaven's Avatar
I would stay away from a puck style clutch for a street driven car. Even the sprung puck clutches are grabby and will start to chatter when they get some age on them. I had the ACT street/strip heavy duty pressure plate combo on my car making 442rwhp with no issues. Great clutch at a great price. However if you plan on spending alot of time at the drag strip with slicks on, you might look for something a bit more.
Old Jun 8, 2005 | 11:17 AM
BoostedRex's Avatar
NorCal 7's Co-founder
Another vote for the Exedy hyper single. Great quality, great durability, and like others have said it isn't bad at all for street use once you get used to it.
Zach
Old Jun 10, 2005 | 08:28 PM
Bad2ndgen's Avatar
How is it on your flywheel and pressure plate?
Old Jun 10, 2005 | 10:44 PM
maxcooper's Avatar
WWFSMD
I've been trying to pay close attention to my Hyper Single and its slippability lately. You can slip it and engage it smoothly. It's just that you don't want to slip it a lot. A little slip while you are engaging it is no problem. Trying to move the car by slipping it with no intention of engaging it fully will make it chatter.
-Max
Snoopy FD
Oct 13, 2016 06:12 AM
risingsunroof82
Sep 9, 2015 08:06 PM
