Haltech HINT: E6X FD Rad Fans higher speed.
Old May 19, 2005 | 08:11 AM
dubulup's Avatar
development
When I installed my haltech, I just followed someone elses diagram...some what.
it only has one wire associated with the radiator fans...the one from the stock ECU.
After studying the fan operation...I decided I would GND the old thermo switch.
It's located on X-14 and is B/R; GNDing this opens a relay(no.4, if I remember correctly) when the ignition is switch ON.
When the fans are actived, this bumps the fans speed up...don't know if it's to med or high?
I didn't see this info when I searched, so I'd report.
DUB
Old Jun 9, 2005 | 12:01 PM
YayeR's Avatar
Whose diagram did you follow? How might I find it? I kind of need some help with my install.
Old Jun 13, 2005 | 07:35 AM
dubulup's Avatar
development
there is good info here http://scuderiaciriani.com/rx7/haltech_install.html
and also the wsm is a must for learning the most out about your car.
Old Mar 18, 2007 | 04:35 PM
dubulup's Avatar
development
well, I don't think many people have done this...which might be a good thing.
As I tracked my battery drain to this...(if I didn't drive the car for two or more weeks, my small gel cell battery would be down on voltage)
It turns out this holds the relay ground even with the key out of the ignition.
and it's relay No. 3 (not 4 as I thought above.)
to fix this, I just tapped the V/W wire from Haltech to this [B/R] wire as well.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
WANKfactor
Sep 29, 2015 01:14 PM
