What makes an engine rev faster?
Old May 13, 2005 | 08:25 PM
F0RSAKEN's Avatar
Cheese
The only things that I know make an engine rev quicker are lighter internals, flywheel, and Ive heard compression?
What could be done to make a 13b-rew rev quicker?
The vid of the F1 car that was posted made me jealous :/
Old May 13, 2005 | 08:30 PM
HAI-TEK7's Avatar
i would add balancing to that list.
oh....and NOS would make it rev faster :-)
Hai
Old May 13, 2005 | 08:35 PM
1QWIK7's Avatar
White chicks > *
less weight of the car
and nitrous
Old May 13, 2005 | 08:38 PM
odditysmurf's Avatar
Anything that will reduce and balance the wieght of rotating mass in the motor will allow it to "rev" faster.
Old May 13, 2005 | 08:57 PM
AnthonyNYC's Avatar
Stay tuned...
Timing
Old May 13, 2005 | 09:06 PM
edv's Avatar
edv
I Like Beer
In the case of rotaries, higher sustained revs require the teeth of the rotors to be replaced with hardened versions.
Old May 13, 2005 | 09:09 PM
user 9348703's Avatar
compression is a good start.
Old May 13, 2005 | 09:35 PM
andrew lohaus's Avatar
lighter flywheel is a biggie
Old May 13, 2005 | 10:08 PM
sillbeer's Avatar
Aluminum driveshaft. Not sure if anyone makes one for the fc. You could try these guys out.
www.driveshaftshop.com
-Destin
Old May 13, 2005 | 10:25 PM
Turbo23's Avatar
Panda Bear
mazdatrix.com sells aluminum driveshafts for FCs
Old May 14, 2005 | 01:04 PM
alloyboy's Avatar
FD3S OWNER
what
there is no timing is there ?
Old May 14, 2005 | 01:05 PM
alloyboy's Avatar
FD3S OWNER
bigger throttle body uprated induction and high octane fuel
Old May 14, 2005 | 02:48 PM
13btnos's Avatar
A heavier right foot!
Old May 14, 2005 | 05:39 PM
maxcooper's Avatar
WWFSMD
A light flywheel makes an enormous difference. Eliminating or underdriving engine accessories probably makes a noticeable difference, too.
-Max
Old May 14, 2005 | 06:07 PM
Andrew.'s Avatar
The end of an era
Lightweight Flywheel
I think they rev so fast cause they don't have flywheels, not sure on this but i think i read that somewhere.
Old May 15, 2005 | 02:29 AM
couturemarc's Avatar
are you talking about what makes an engine rev up faster or rev higher? there's no trick to higher rpm aside from just having a really good engine that can breath at the rpm you want.
Old May 15, 2005 | 10:08 AM
peejay's Avatar
Old [Sch|F]ool
Don't forget everything attached to the engine, like accessories... the transmission shafts... the rest of the drivetrain...
It's all veddy important!
And proper tuning is also very important!
- Pete (F1 = Functions Once)
Old May 16, 2005 | 12:52 AM
F0RSAKEN's Avatar
Cheese
Im interested in the crisp, instant throttle response of something like a Ferarri.
Old May 17, 2005 | 09:47 AM
1QWIK7's Avatar
White chicks > *
F1 cars are light, have alot of hp and their engines have such a short stroke, thats why they rev high and fast..
Old Jun 1, 2005 | 04:56 PM
Nihilanthic's Avatar
moon ******
How fast it revs up is basically a measure of the torque it makes and how heavy the engine/flywheel/accessories are.
So, if you were running it stripped for racing w/ a light *** flywheel and it was on boost, it would rev fast as hell. However, off boost, the rev increase wont be as fast.
(Yeah I know this is totally not the answer you want) The 'fastest revving' engine I can think of that you could conceiveably get would be some stroked out supercharged v8 with a light flywheel and minimal accessories out of gear. Unfortuantely it wont rev all that high unless you put in forged EVERYTHING and have some serious valve springs. :P
So, for a turbo rotary to spin up fast, stock twins in sequential w/ all the breathing mods and a light flywheel and underdriven accessories.
Old Jun 1, 2005 | 05:34 PM
diabolical1's Avatar
lighter rotating assembly, lighter driveline, compression and gearing are all fine, but the design of your intake system plays a role in response and revs. i'm surpised no one has mentioned that point specifically.
Old Jun 1, 2005 | 05:45 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
I have an os gilken twinplate with its light *** flywheel on my cosmo re powred fc
Engine revs and recovers very quickly, sounds sport bikeish
-Jacob
Old Jun 1, 2005 | 10:37 PM
MR_Rick's Avatar
Planning my come back
I don't think this is correct. To my understanding F1 car are required to use the same motor per race including qualification round.
Old Jun 1, 2005 | 10:51 PM
rynberg's Avatar
Actually, under the current rules, they must run the same motor through TWO race weekends.....if they swap motors early, they take a 10-position penalty in qualifying.
Old Jun 1, 2005 | 10:57 PM
MR_Rick's Avatar
That's what I heard but wasn't sure if it was the weekend. Thanks
Queppa
Nov 18, 2024 03:47 AM
Kyo
Apr 13, 2019 09:24 AM
Tannergsl-setarga7
Aug 18, 2015 03:11 PM
befarrer
Aug 14, 2015 04:18 PM
