Sponsored by: CARiD
too much oil wrecked the engine?
Old May 13, 2005 | 12:03 PM
Robbierx7's Avatar
Unhappy too much oil wrecked the engine?
My mom phoned my dad from london yesterday saying that her 1999/2000 vw passat 1.8turbo had broken down. It gradually got slower and slower on the mototway and when in traffic it cut out completley. She called the breakdown service and the mechanic said that she there was too much oil in the engine. She admitted to adding oil before the journey,but only a cup full. having got it back home my dad suggested taking it straight to volkswagon as she needs the car asap.They said that a lot of damage has been done (camshafts sheared or something like that) they estimated a £3k to £4k cost!
I have just found out off my dad that the car is down the vw garage being stripped for inspection and i told my mom to get it out of there asap as the vw dealer will charge a fortune for stripping the engine.
i just think its weird that the engine can be wrecked with a bit too much oil. can anyone shed some light on this?
thanks guys,any info would be really welcome.
Old May 23, 2005 | 08:49 PM
Turbo 3's Avatar
Safety Guy
having too much oil will do as much damage to bearings as having too little. If there's too much, the crank has to work harder to splash through the oil, thus heating it up more and heating up the sleeve bearings more as well.
hope that helps
Old May 24, 2005 | 07:11 AM
RETed's Avatar
Adding a "cup" should not have done that kinda damage.
Unless your definition of "cup" is different than what most Americans call a "cup"!
Adding too much oil in a piston engine raises the oil level to the point that the crankshaft and con rods starts to slosh in the high oil level.
In extreme cases, the bottoms of the pistons start to slap the surface of the oil, and this will blow piston rings and cause a LOT of damage.
Adding a liter of oil over normal should not cause the above.
It typically takes closer to 2 liters or more of overfill to cause damage like that...
BTW, this is in the wrong section - it should be moved to "General Automotive".
-Ted
Old Jun 2, 2005 | 09:40 PM
N1XRR's Avatar
With Mechanics as with Doctors...
GET A SECOND OPINION!
Old Jun 12, 2005 | 04:09 PM
skrewloose78's Avatar
Anti-rice Superstar
did she check the dipstick before or after she added oil?
Old Jun 12, 2005 | 04:58 PM
Aeka GSR's Avatar
a high oil level gets aireated by the crank and the bearings are starved for oil.
Old Jun 14, 2005 | 08:37 AM
FCkyou's Avatar
True too much oil will damage an engine, but shear a cam? Come on!?!
Old Jun 18, 2005 | 12:01 PM
slpin's Avatar
7th Heaven
and lots and lots of oil foaming.....
doubt thats what happened......
Old Jun 24, 2005 | 05:13 PM
FormulaRX's Avatar
My name is Ted-E
can the powertrain warranty cover it? I hope she didn't tell the dealer that she added oil to the car...they can use that against warranting the problem
BLK 93
Aug 19, 2015 03:47 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
