Sponsored by: CARiD
No fuel...No spark..
Old May 3, 2005 | 01:04 PM
danec020's Avatar
Ok guys I just finished installing a first time self rebuild as well as removed emissions using Rotary Resurrections guide. My car is an 88 turbo 10th AE if anyone needs to know. The car cranks, but I get no fuel or spark. The fuel pump is working, I pulled it out and cranked it while wired but unattached and it sprayed the fuel in it about 10 feet :P.
I pulled the plugs, no fuel on them, they were dry as can be. Then i put them against the metal on the intercooler and cranked the engine and I had no spark. So... What could the problem be?
Could the no fuel be caused by the fuel pressure regulator? I have it attached to the nipple on the inside of the LIM, the on that is angled towards the firwall in the middle of the LIM right above the oil injectors. That vacuum should work correct? As for the spark, is there some wiring i should look for?
Also could anyone post a picture of the knocksensor on the S4 turbo? I searched the forums and found locations for it, on the rear housing slightly higher than the plug holes, and several others but I have yet to find that thing! I have the sensor in my hand so I know I took it off lol.
Thanks for any help guys! I Appreciate it.
DaneC020
Old May 5, 2005 | 12:40 AM
danec020's Avatar
No suggestions?
Old May 6, 2005 | 06:38 PM
silver93r1's Avatar
What it is Hoe, Wussup
check your wiring harness has it benn sliced samething happend in my friends fd
Old May 7, 2005 | 04:29 PM
HAILERS's Avatar
HAILERS
No spark and no fuel equals a blown ENGINE fuse. Remove and replace same.
Old May 16, 2005 | 11:51 AM
danec020's Avatar
Still no go...
Ok, i have checked the wiring harness and i have replaced the 80A fuse and the EGI Fuse for the fuel pump... Same problem, engine cranks strong, but no fuel or spark...
Any help would be appreciated, I am currently out of the states now but will be back in 2 weeks. Anything to try that I havent would be awesome, I want to try to finish up this car before classes next semester.
Thanks again guys! I can feel her wanting to start
Dane
Old May 24, 2005 | 09:18 PM
HAILERS's Avatar
HAILERS
It's spelled E N G I N E F U S E
It is located in the car near your left ankle.
EGI spells I G G Y, not engine.
Old May 28, 2005 | 08:38 PM
Michael Smith's Avatar
The knock detector can be on the rear housing or on the centre housing just under the oil filler it looks like a big nut with a wire out of the centre.
Michael Smith
P.S. it doesn't kill the spark and fuel if it doesn't work!
Old Jun 11, 2005 | 05:41 PM
danec020's Avatar
Well guys I am back in the states and I checked the ENGINEFUSE and it is fine... Still no fuel or spark. Is there any other electronics that control this.. Like I said, I checked the fuel pump it is actually pushing fuel, but why isnt it making it to the engine? Maybe a kink or one of the emission vacuums wrong? (I removed emissions as I stated earlier)
Old Jun 11, 2005 | 09:41 PM
Syonyk's Avatar
Main relay in the back driver's side corner of the engine bay?
-=Russ=-
Old Jun 12, 2005 | 02:28 PM
danec020's Avatar
I have been searching the forums for info about the Main relay, it seems quite possable that it could be the problem. Only problem, I cant find it. I am looking through the FSM and went through all the Main Relay post, no luck yet. I also found this yellow plug that comes off the wiring harness halfway between the fire wall and the intake. If you can visualize what I am saying, is that just for the air pump that I removed for emissions? (Looks in that area)
Old Jun 19, 2005 | 01:28 AM
danec020's Avatar
Ok guys, getting better. I finally got spark, it was a ground issue. Now the problem is fuel. I checked the fuel pump it is sending fuel. I checked all the fuses and all fuses are good. I just pulled the CAS and had the key on ON position and I turned it by hand. I could hear the injectors clicking. So I am assuming my injectors are fine and that somewhere there isnt fuel sent to the injectors. What could cause this? Pressurizing the fuel system? Bad vacuum source to the FPR? Maybe something not pluged in on the ECU or wiring harness? Anything you guys can give some info on would be much appreciated. I been searching and will be searching as your are reading this probably. Thanks for the help
Old Jun 19, 2005 | 02:01 AM
danec020's Avatar
Sorry It wouldnt let me edit.. I just wanted to state that my fuel lines are hooked up correctly from the fuel pump to the filter to the rail and back to the tank. If the pump is working and the injectors are clicking and the lines are hooked up correctly, then in theory shouldn't it be getting fuel? Maybe it is and I just dont smell it on the spark plugs? Could it just be an issue of timing? Please any help would be much appreciated.
Thanks again
Old Jun 23, 2005 | 10:36 AM
danec020's Avatar
Any input? I also found that my throttle body had a huge leak where the intake manifold connects to it. The intake manifold was cracked and had an opening bigger than a 50 cent piece. That could also be a problem correct? =P. I got a new intake manifold on the way. If I put it on and it still doesnt start, does anyone have any other suggestions? ( have to wait till the weekends to work on it cause its out of town, so I would like to get a list of things to go out there with.)
I appreciate the help, thanks again.
Old Jun 28, 2005 | 11:08 PM
prjct87rx7's Avatar
REST IN PEACE DAVE!!!!!!
did you change the main fuel filter? located on the fire wall...and so you know the s4's knock sensor is on one of the irons/plates.screw onto the fron of either you front or middle iron.and on the s5 its on the housing right above the spark plug holes..
Old Jun 29, 2005 | 04:42 PM
danec020's Avatar
Yeah the main fuel filter has been changed and I found the knock sensor. Hopefully she will start up this next try =P.
Dane
Old Jun 30, 2005 | 02:48 AM
diabolical1's Avatar
i can't remember the Gen II cars very well, but if there is more than one fuel line, make sure that they are not reversed.
gjacks1857
SE RX-7 Forum
Jun 5, 2013 11:36 PM
Sirrx
Aug 26, 2008 09:40 PM
RochX7
Mar 31, 2008 05:26 PM
Ottoman
Mar 23, 2005 08:06 AM
