Power FC Changing injector size
Old Apr 29, 2005 | 01:22 AM
ckanderson's Avatar
This question if for a Toyota Supra engine, but you guys know way more about the Power fc.. so I'll ask you..
The stock injector's are 370'cc. I have a set of 880'cc that I would like to install. I have the FC and I have the commander. How do I change the injector setting's to accept these new injectors?
Thank you,
Chris
Old Apr 29, 2005 | 08:55 AM
DaleClark's Avatar
RX-7 Bad Ass
FYI, you very likely will have a tough time getting the car to idle properly with injectors THAT much bigger than stock.
I'm not well versed in injector size changes, but I believe that's been covered - do some searching and see if you can find some answers.
Dale
Old Apr 29, 2005 | 11:49 AM
ckanderson's Avatar
Would the Datalogit help in any way? I dont currently have that, but I have been thinking of getting it.
Old Apr 29, 2005 | 12:47 PM
jeff48's Avatar
Rotorally Challenged
If Datalogit is available for the supra Power FC then by all means get it. If all things are equal between FDs and Supra Power FCs you may be able to up the size of the injectors directly from the commander. Look to the screen that has the injector sizes on it, you should be able to change the injector sizes by using the "up down right left previous and next" keys on the commander.
In the FC-Edit software that comes with the datalogit, there is a screen for setting injector size and lag. Once you do that, the datalogit adjusts the base map to reflect your new setup.
Good Luck
Old Apr 29, 2005 | 05:09 PM
ckanderson's Avatar
I belive I have almost all the screens you do, except trailing and leading injectors (obviously).
I have looked at the injector screen, all injectors are at 100 percent. so I just need to lower it down to right around 42 percent?
370/880=0.42
Old Apr 29, 2005 | 06:52 PM
jeff48's Avatar
Actually on the commander you should have a screen for injector size and it should currently read 370. If you can change it by means of the Up Down keys, you will be given choices. If 880 is a choice, all you have to do is select it and let the PFC do the rest.
You are looking at injector duty cycle, which is not the same.
Old Apr 29, 2005 | 07:56 PM
ckanderson's Avatar
After reading the power fc manual, i belive i got it right.. Ill let ya know when im done...
Old Apr 29, 2005 | 10:16 PM
ckanderson's Avatar
well i guess i did it wrong or my injecotrs are screwed up.. I couldent get it to run right... Im going to send these injectors back and try some 550's... Thank you for your help guys!
FD7KiD
15
Feb 26, 2021 10:12 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
