Anyone Need There Rx-7 Worked On In Easter Nc?
Old Apr 26, 2005 | 10:03 PM
coolcars44's Avatar
IF THERE IS ANYONE IN EASTERN NC AROUNDTHAT NEEDS THERE RX-7 WORKED ON I RUN A SHOP IN WASHINGTON NC I WORK ON RX-7 CARS ONLY AND HAVE BEEN FOR THE PAST 8 YEARS I BUILD MOTORS AND DO JUST ABOUT ANYTHING YOU NEED DONE TO A RX-7.IF YOUR NEAR ME AND NEED SOME WORK DONR OR WANT TO HAVE A RX-7 BUILT MAYBE I CAN HELP YOU OUT.JUST PM ME OR EMAIL ME IF YOU HAVE ANY QUESTIONS COOLCARS44@PEOPLEPC.COM I ALSO TOW CARS SO IF YOUR A LITTLE FURTHER AWAY I CAN HELP MOVE WHAT YOU GOT IF IM WORKING ON YOUR 7.
Old Apr 27, 2005 | 08:45 AM
90WhiteVrt's Avatar
FC4ME
How far is that from Raleigh???
Old Apr 27, 2005 | 10:18 AM
coolcars44's Avatar
im about 2 hours from you.l
Old Apr 27, 2005 | 09:51 PM
coolcars44's Avatar
ok ill post some of my labor prices for you guys near me
remove motor install used/new motor 300.00 bucks for n/a cars t2 cars your looking 370.00
tear motor down and install rebuild kit 300.00 dollars n/a or t2 motors
so to remove your motor tear it down rebuild it reistall it and tune it will cost you 600.00 total labor.what ever parts you need for the motor build i can find online for you such as rotors or housings and plates.now i do have alot of spare motor parts and always buying cores so i more than likely will have the stuff already.any other mods such as porting or install 3mm seals will be extra labor of course.
now i will only use rotary aviation parts or any single apex seal kit.i usually use the rotary aviation basic kit which is 540.00 dollars
to install clutch 200.00 labor
remove injecots have them cleaned etc etc work like this is usually 100.00 dollars or so
any rx-7 i work on will first before anything have the fuel pressure checked most rx-7 i have seen have low fuel pressure from either bad fuel filter or just worn out fuel pump
if any mods are being done you must buy a walboro 255 fuel pump and good flowing clean injectors.
other labor charges just depend on what we are doing to car such as suspension work or installign fenders or fixing driveshaft etc etc but prices are good and within reason.
anyways just pm me or email me and ill answer any questions you might have
Old Apr 28, 2005 | 07:01 PM
coolcars44's Avatar
bump
Old May 1, 2005 | 07:38 PM
coolcars44's Avatar
bump
sherff
Feb 24, 2019 12:09 PM
Samsquanch
Sep 8, 2015 04:51 PM
plentymoon
NW RX-7 Forum
Sep 5, 2015 08:55 AM
sYnth.
Aug 19, 2015 06:27 PM
