Size of Speakers in a FC?
Old Apr 20, 2005 | 02:14 AM
xCH121Sx's Avatar
Question Size of Speakers in a FC?
hey guys what are the speaker sizes for a 86' FC GXL if it matters.
Old Apr 20, 2005 | 03:49 PM
skb18215's Avatar
Its delicious
in the shock towers?? what speakers? the ones in the front under the dash and 4.5", the ones in the shock towers are 6.5"
Old Apr 20, 2005 | 11:12 PM
xCH121Sx's Avatar
yeh i wanted to kno all of em... my car didnt come with speakers... arent their speakers on the door panel?
thanx for the info...
Old Apr 22, 2005 | 01:35 AM
JKM's Avatar
JKM
Some of the later models had speakers in the door (6.5 inches) but I don't think your 86 does.
The shock tower opening is actually 8 inches wide, with an adapter in it for either 4" or 6 1/2" speakers, depending on model. If you need one, you can get 6 1/2" adapter kits from crutchfield.com or off of ebay. Or, if you are so inclined you can make your own ghetto solution like I did.
Old Apr 22, 2005 | 09:46 PM
ibemrzach's Avatar
yeah, 4" under the dash and 6.5 in the doors and towers. I work at the roadshop at circuit city and i've also seen factory molds behind the carpet that fit 4x6 behind each seat; that particular appliation was in a s4 coupe. don't forget your system is probably factory amplified so you'll want to do an amp bypass. If you run a 4/5/6 channel up front you can just avoid that mess, and that's what i'd recommend.
naert
Shainiac
Jul 17, 2019 02:20 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
