Sponsored by: CARiD
testing TPS?
Old Dec 28, 2001 | 07:09 PM
testing TPS?
i have a 88 vert with a 89 intake with brand new injectors,full racing beat exhaust,and a k&n air filter i just got it back and the idle is rough and i have to floor the gas to get it to start the guy tried adjusting the TPS but said it wouldnt adjust out i never had any problems with it before the mods but hee said it was because my timing was so advanced, is this true? it doesnt have the usual symptons of a tps like jumping from 700to1500 it just idles rough and has like a fuel miss is there any way i can test the tps with a ohm meter? and how would i go about doing it? the car pulls a wole lot better since the mods but im not happy with the idle i dont like to push in the clutch and turn a corner and the car cuts off,not fun any help would be appreciated im going to try and swap out the afm and see if that helps i have an air fuel guage and it does show that it is running lean thanks,Dave
Old Dec 31, 2001 | 10:03 AM
HAILERS's Avatar
HAILERS
Which TPS are you using??? The 88 or the 89????? On the 88 car??????
Old Jan 1, 2002 | 05:39 PM
im using the 88 i ordered a new one but i still dont see a adjustment on the TPS what would it run like if i just put a new one on would it still need adjustment due to the mods?
Old Jan 2, 2002 | 06:33 AM
Felix Wankel's Avatar
Super Newbie
I think you may need the 89 TPS. I'm not too sure, I don't get to mess with S5 cars much
Old Jan 2, 2002 | 09:19 AM
i have the 89 intake but i have to use the throttle boddy from a 88 the car runs fine when im running it its just when idles the car sometimes wants to cut off when i turn corners and idles basically where it wants to sometimes 750 sometimes 1500 just depends on its mood i guess i ordered a new TPS for a 88 but was wondering wheres the adjustment and if i would have to adjust it due to my mods?
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 18, 2015 07:13 PM
localized
Sep 16, 2015 12:18 AM
ZaqAtaq
Sep 5, 2015 08:57 PM
