Injector size
Old Dec 27, 2001 | 01:55 PM
Codey's Avatar
Injector size
I have an '89 GTU that has a street ported 13B. The primaries have barely been touched, however the secondaries have been ported. The rotating mass has also been balanced. Currently I have the stock injectors. I am contemplating 720cc injectors for the secondaries and keeping the primaries stock. Exhaust is RB header with presilencer and DynoMax mufflers...no cat, low backpressure. What size injectors would you buy and install? Also what would be your next upgrade? Thanks
Old Dec 27, 2001 | 03:24 PM
cymfc3s's Avatar
I Raise Chickens
for a normal aspirated motor, keep the injector size stock. Bigger injectors on the stock ecu will make it run too rich.
Old Dec 27, 2001 | 09:31 PM
FPrep2ndGenRX7's Avatar
Contrary to what others on the forum will tell you, the stock injectors will support just over 200HP at 85% duy cycle.
Old Dec 27, 2001 | 09:52 PM
Scott 89t2's Avatar
SOLD THE RX-7!
720 is way too big. if you really need bigger injectors get the stock turbo ones which are 550cc, but unless you have a way to tune them in like a S-afc it'll run worse.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
