Hooking up a LM-1 and a automter a/f gauge. Quick question.
Old Apr 5, 2005 | 07:58 PM
pp13bnos's Avatar
Pineapple Racer
This may not be in the correct forum, but I feel that I get more quality responses to my questions in this forum. That, and I don't feel that there realy is a correct place for my question.
Anyways, I'm running the LM-1 for my wide band. The biggest pain is that its extremely large, and kinda hard to read when accelerating hard. So I've put it in my glove box. Now, what I was thinking was that I have a Autometer a/f gauge laying around from the days of my n/a Rx-7 days. And seeing as its hard to keep an eye on the a/f ratio while doing hard runs, I wanted to hook it upto my Autometer. The only problem I've having is that I don't know how many volts it runs off of. Is the guage a 0~5v or what? I just need to know this so I can setup my LM-1 correctly. Any help would be great. CJ
Old Apr 5, 2005 | 08:19 PM
andrewb70's Avatar
Check out this link:
http://hp.autometer.com/instruction_...tions/837j.pdf
On the last page of the instructions there is a voltage chart that shows at what voltage the various LEDs on the Autometer gauge light up. You need to program one of the LM-1 analog outputs to corespond to the volotages taht are listed on the Autometer instruction sheet. Once you have your voltage curve programmed into the LM-1 and you connect the analog output wire to the gauge the lights will work properly. The Autometer gauge is basically a 0-1V gauge, but you can make it work since the LM-1 allows you to program the output voltage to whatever you need.
Andrew
Old Apr 5, 2005 | 09:15 PM
pp13bnos's Avatar
Pineapple Racer
Thats exactly what I wanted to know. Thanks! CJ
Old Apr 6, 2005 | 03:28 AM
jasrx's Avatar
im pretty sure u can buy a gauge like the autometer typr for the LM1.?
Old Apr 6, 2005 | 09:49 AM
andrewb70's Avatar
Your welcome. I had the exact same setup working, so I am sure it will work for you. By playing around with the LM-1 programming you can pretty much make any LED light up on the Autometer gauge. So you can make the green LEDs light up at say 11:1 AFR and the yellow LEDs light up at 12:1 AFR. Pretty much any combination that you wanted. I would also program in a little bit of a delay into the output that goes to the gauge. That way the LEDs aren't jumping around TOO fast. Good luck!
Andrew
Old Apr 6, 2005 | 03:41 PM
bolo_fd's Avatar
thanks guys. i just got a lm1 and i had a autometer a/f gauge from my old car.
Old Apr 6, 2005 | 05:56 PM
pp13bnos's Avatar
Pineapple Racer
I'm going to buy a dual pod gauge holder then hook it up. CJ
Old Apr 7, 2005 | 03:55 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
Wow, kick *** idea. Can you post the output setup for us other people? I have an LM-1 and LMA-3, however with only one person in the car (myself) all i can do also is datalog
Old Apr 8, 2005 | 11:52 PM
pp13bnos's Avatar
Pineapple Racer
So, what exactly was youre setup andrewb70?
I put mine at a 0v = 15 a/f ratio, and 1v = 10.0 a/f ratio. I'm yet to test it...but I'm hoping it works correct. CJ
Old Apr 11, 2005 | 05:03 PM
pp13bnos's Avatar
Pineapple Racer
I had a chance to test it on Sunday. I'm honestly very happy with it. Something I wish I would have done along time ago. I am going to adjust the voltage a bit....going to run 0v=15 a/f and 1v=11 a/f. This way under WOT, the guage should read full green. And if it does'nt, its time to back off of it. CJ
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
musker
Oct 1, 2015 05:58 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
MidnightOwl
Sep 25, 2015 10:24 PM
