For Those who Own Apexi AVC-R..
Old Dec 26, 2001 | 05:06 PM
RevHigh758's Avatar
Exclamation For Those who Own Apexi AVC-R..
I have just finished the installatioin on my TuboII and I came up with some questions..
On the installation manual it says .."Never start the engine or turn the ignition key ON/OFF while the AVC-R is in use"
Does this mean that the *AVC-R* has On/Off Switch?? I couldn't find anything on the manual about how to turn it On/Off manually. Mine just illuminates when I turn the key ON and Turns off when I turn the key OFF..
I am just a bit confused about their instructions..
HOW do you turn your AVC-R ON/OFF ( I mean the whole unit )??
Thank you for your time and have a nice day
Old Dec 26, 2001 | 09:44 PM
fc3s.org's Avatar
OG
They mean while you are changing things don't turn off the car or start it if it isn't on already. In otherwords, don't change the status of the ignition while changing parameters in the AVC-R
Now isn't that clear as mud for ya?
Old Dec 26, 2001 | 10:06 PM
RevHigh758's Avatar
So.. it doesn't have a seperate on/off switch other than when you turn your car on/off??
Thanks
Old Dec 26, 2001 | 10:07 PM
fc3s.org's Avatar
OG
Nope, it is controlled by the accessory/switched 12volts on your ignition. No other way to turn it on or off
ls1swap
Jun 3, 2024 03:25 PM
