Haltech e6k showing 100% duty while cranking?
Old Mar 27, 2005 | 12:30 AM
jacobcartmill's Avatar
just dont care.
would anyone else have any cluewhy my e6k is showing 100% duty while cranking? what should the duty cycle be during cranking?
Old Mar 28, 2005 | 12:23 AM
J-Rat's Avatar
Alcohol Fueled!
That doesnt sound right. At 100% duty cycle, the injectors are firehosing the engine..
Old Apr 7, 2005 | 09:08 AM
pistonsuk's Avatar
100% Duty While Cranking
check:
Maps:
battery voltage, post start, and fuel below 1k and vacuum.
Main Setup:
make sure your MAP sensor matches what you have in the software setup
i had a wire near my ecu short and this caused the engine to go so rich it would not run below 2K. (wasnt datalogging so i dont now what duty). check for shorts
try looking at the "engine data page" online before cranking... anything weird?
justin
Old Apr 7, 2005 | 09:10 AM
pistonsuk's Avatar
Duty
while the fuel pump is priming the injectors should pulse. this usually blips the duty to ~4-10% depending on primer map.
while cranking the duty is ~6%. it is surely less than 10%
justin
Old Apr 8, 2005 | 01:06 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
Is your car turbo or NA? where is the arrow on top of the bars at when you crank? the only reasons i can think of right now are a faulty map sensor reading, a correction map out of wack, RPM spiking (to 16000rpm) due to noise in the trigger, making the ECU pulse the injectors all the way.
Old Apr 11, 2005 | 11:41 PM
just dont care.
problem went away after haltech re-install. thread can die now
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
