my tach doesn't work.
Old Mar 20, 2005 | 09:07 PM
r1cheer1ch's Avatar
R1cheer1ch
Thumbs down my tach doesn't work.
my tachometer does not work no more. last time it worked i was driving in heavy rain. every now and then it comes on and off, only when the car is on for a little while. anybody else have this problem? don't really know what to check first, can anybody help me troubleshoot this?
Old Mar 20, 2005 | 10:12 PM
oneflytrini's Avatar
Stabbed by a pen
I bought my car, and the tach never worked. Had the car for about 3-4 years, and just got used to shifting by looking at the speedo. The tach problem is common on FD's, the connectors on the back of the tach usually just "rust" out, and then need to be resodered. That might be the problem, but there are also different problems that would make your tach not work. Pull out your cluster and check it out, but be careful when pulling out the cluster as the clips are very easy to break. Just remember to pull it "towards you".
Old Mar 21, 2005 | 06:16 AM
RexRyder's Avatar
ck ur fuse
rgordon1979
40
Mar 15, 2022 12:04 PM
