Haltech E6X trigger issues
Old Mar 20, 2005 | 07:50 PM
MrRx's Avatar
Rotary on a budget
E6X trigger issues
Hello, I recently finshed my haltech install among other parts and so on.
well last night i went to test fire her to check the trigger and so on, everything was fine, it picked up a steady trigger and so on.
I go out there today and nothing no pickup at all, Any idea what may have caused it, I know my actually CAS is working when cranking I can pick up about .650 Volts.
Im not sure what its supposed to be.
Any ideas?
Old Mar 21, 2005 | 02:10 PM
dubulup's Avatar
development
if the battery isn't charged enough...I've experienced no pick-up.
make sure all GNDs are solid.
What are your gains? It seemed on mine, 0 worked the best.
Old Mar 21, 2005 | 09:34 PM
tims's Avatar
I had the battery issue just this weekend. Had to replace the battery, charging would not fix it. I also had a bad or loose connection at the CAS connector. Use dielectric grease on all the connector to insure a good connection.
Old Mar 21, 2005 | 09:49 PM
MrRx's Avatar
Rotary on a budget
well,
I checked all the gounds, there as short as possible and very solid,
my battary is brand new redtop.
its weird, sometimes it works with the gain at 0, sometimes at 2, once at 7, it just randomly start to work, then dies. I think the unit is messed up, I email haltech but havent heard back from them yet.
Old Mar 22, 2005 | 11:48 AM
Sesshoumaru's Avatar
Tenseiga
https://www.rx7club.com/haltech-forum-62/my-turn-e6x-problem-400275/
seems similar
Old Mar 23, 2005 | 12:05 PM
MrRx's Avatar
Rotary on a budget
yep, I got my responds from haltech today, they basiclly said I could try to replace my cas or just send it in, so im sending it in. fun fun
Old Mar 23, 2005 | 04:09 PM
dubulup's Avatar
development
lots of shipping costs :EEK:
Old Mar 23, 2005 | 05:46 PM
tims's Avatar
Has anyone used the S1 or S2 switchs with a chopper wheel on any application? I was thinking this may give a clearer signal. I was thinking to build a wheel and bracket and see how this works. so anybody with some first hand experience please leave your results.
Old Mar 25, 2005 | 09:03 PM
RE-EGI's Avatar
the e6x i run will receive no cas signal for about 3 sec sometimes, then it starts working. mabye you need to crank it a little longer.
Old Mar 30, 2005 | 04:20 PM
MrRx's Avatar
Rotary on a budget
I am cranking for at least 10-20 seconds with the injectors turned off,
Ive been gone all week so I think im going to try a few more things before i send it in.
first, does anyone about how much voltage the cas should be making while cranking? that could help me test it.
I also noticed my connector wires were all rock hard, so im going to see if i cant repair the connector and see if that fixes it.
Old Mar 30, 2005 | 07:01 PM
tims's Avatar
I recently had an issue with the CAS connector and I know rted has had issues with this plug before. To test the CAS you would need an oscillascope(sp?). for my problem I just disconnected the plug cleaned it with contact cleaner and put some dielectric grease on the connectors. I also find that a new(not cleaned) set of spark plugs helps to get untuned engines running easier. good luck
ZacMan
Sep 19, 2015 09:20 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
windom
Sep 11, 2015 04:48 AM
dillrx7
Sep 7, 2015 09:38 AM
