Brake Size On A Second Gen?
Old Dec 22, 2001 | 11:09 PM
Snufelupogus's Avatar
Do I Really Exist?
Question Brake Size On A Second Gen?
Hey, I was just wonder what the size of the brake rotors/discs are on a second gen, like GXL or something. They any bigger than 10" in diameter? Im going to be putting 13" rims on my car and I need to know if they are going to be small enough to fit inside the rims or will I have to find some smaller discs to put on there.
Thanks for any help.
Old Dec 23, 2001 | 11:56 PM
Silkworm's Avatar
Has been.. hangin' around
GXLs had 10.9s 4 piston brakes up front, 10.7 Singles in the rear. I don't think the single piston fronts from the base were much smaller. Why are you going to such a small diameter wheel? Drag slicks?
Lates,
PaulC
Old Dec 25, 2001 | 12:31 AM
Do I Really Exist?
Yeah I wanna put drag slicks on the car.
13 inch rims.
I just need to know if they are going to fit over top of the brakes without any problems.
thanks
Old Dec 26, 2001 | 03:24 PM
FPrep2ndGenRX7's Avatar
I don't think you can put anything less than a 15" on the front. The brake caliper is in the way. The rear my be different but I don't think so. The 2nd Gen's with the 4-lug suspension had factory 14" rims so that might be an alternative for you. Just swap the rear brake assemblies out, but then the brake portioning valve will not like what you have done. That could make the brakes unreliable and if your drag racing brakes are very important after you go 1/4 mile. Hell, brakes are important all the time. You might as well just go with a 15" rim and change the rear gear ratio to a 4.30 or lower.
I no help at all, am I?
Old Dec 26, 2001 | 06:49 PM
Scott 89t2's Avatar
SOLD THE RX-7!
if you have the 5 lug 4 piston brakes you can't go smaller then 15".
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
