what removes stock FD interior paint?
Old Mar 17, 2005 | 12:09 PM
jmo87's Avatar
Question what removes stock FD interior paint?
Searched but couldn't find... My FD interior pieces are all scratched and nasty. I've seen a few people who just "accidentally" removed the paint and underneath was a glossy finish so they left it. Anyone know what to use to get it to that point? Thanks!
Old Mar 19, 2005 | 12:15 AM
Daniel577h's Avatar
danny rocks
if its a 93 with that plasticy type interior i used some stuff called ELO " easy lift off" i bought it from a hobby store, worked out pretty good, just let it soak in for a while
Old Mar 19, 2005 | 08:20 AM
jmo87's Avatar
yeah im gonna pick some up today. thanks.
Old Mar 19, 2005 | 02:34 PM
rxseven07's Avatar
Registered pimp
try brake cleaner
Old Mar 19, 2005 | 02:57 PM
d0 Luck's Avatar
raysspl.com
"aircraft remover"
Old Mar 21, 2005 | 06:14 AM
RexRyder's Avatar
methyl ethyl ketone
Old Mar 21, 2005 | 09:58 AM
blownoffvalve's Avatar
yes aircraft remover is good stuff
Old Mar 21, 2005 | 10:49 AM
dclin's Avatar
Perpetual Project
As was mentioned above, ELO works well. I've found it to be safe on plastic, takes a couple of applications but the paint rubs/peels off with only a bit of effort.
http://www2.towerhobbies.com/cgi-bin...?&I=LXYB89&P=7
My local hobby shop had a bigger container then in the link above, which you'll need to do doall the painted plastic '93 panels.
Old Mar 21, 2005 | 06:00 PM
LDawg's Avatar
Can anyone post pictures of what the dash looks like after the paint was removed? Thanks in advance.
Cheers,
Lam
Old Mar 21, 2005 | 08:09 PM
dclin's Avatar
Perpetual Project
Cheers,
Lam
Just smooth ('93s anyways) black plastic, kind of semi-gloss IIRC. Most people remove to repaint of course, and it would look on the cheap side if left 'bare' IMHO. Less to worry about though...
Old Mar 21, 2005 | 10:47 PM
speedx7's Avatar
Rotors keep you going
Thanks for the info guys I'm gonna have to do this myself aswell
Old Mar 22, 2005 | 03:39 PM
mrb63083's Avatar
I took off all the paint on my shifter panel, it was a little too shiney for me. So i scuffed it up with sandpaper and painted it flat black. Looked decent.
Old Mar 22, 2005 | 03:50 PM
Mahjik's Avatar
Mr. Links
Arrow
Some pics from my project a few years ago:
https://www.rx7club.com/showthread.p...hreadid=168938
Old Mar 22, 2005 | 05:10 PM
travisorus rex's Avatar
Avoid the Noid
How about sandpaper and a little elbow grease.
Old Mar 22, 2005 | 06:47 PM
Mdessouki's Avatar
not a good idea because if you leave any paint it will lift when you put on the new stuff. I used 50/50 prep solve and laquer thinner. Stripped it in a matter of seconds.
Old Mar 23, 2005 | 01:42 PM
LDawg's Avatar
Thanks for the pictures Mahjik! Now I am a bit confused and need some clarification. I know there is a difference between the 93 and 94/95 dash material, but I always thought the areas referred to were the dash (you know the huge flat area where the center speaker, PS air bag, front windshield vents, etc. are) and tranny tunnel piece with the skin-like texture. So is the material difference referring to the gauge cluster, A/C panel, and shift panel or is it referring to what I originally thought it was? I hope this is not confusing for anyone.
Cheers,
Lam
Old Mar 23, 2005 | 03:06 PM
Mahjik's Avatar
Mr. Links
Hey Lam,
The actual A/C panel and other panels had a "texture" to them for the 94/95's. If you like theh textured look, you can always just order the 94/95 interior pieces. They snap right in onto 93's and they aren't too expensive. My buddy "ebb" here on the forum just changed his over so the prices are probably still fresh in his brain if you want to PM him.
Frisky Arab
13
Aug 18, 2015 05:30 PM
