Sponsored by: CARiD
Rotor Coating?
Old Mar 16, 2005 | 09:35 PM
skyburner's Avatar
Rotor Coating?
Ok, I searched the forum and can't find the answer to what is probably a stupid question. Do the rotor combustion faces have a coating on them from the factory? Reason for question is this, I disassembled TII engine and had lots of build up on rotors. I cleaned them with a wire brush and carb cleaner to the point that I believe they are bare metal. I also disassembled a NA engine and the rotor in it looks like it has some sort of couting on it. (shiney, compared to TII) Did I remove some coating or something? This is my first rotary rebuild and I don't want to screw it up. Thansk for the help.
Old Mar 17, 2005 | 05:59 AM
maxcooper's Avatar
WWFSMD
I am not aware of any coating on stock rotor faces. It is common to clean them vigorously during a rebuild, so your cleaning should be fine.
-Max
tiger18
Sep 3, 2015 08:27 PM
