Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D Rotary Split
Old Mar 11, 2005 | 12:39 AM
signofinfinity's Avatar
Coyote
Cool Rotary Split
The much sought after question..... How much split??
This is my Split table.....
your opinions?
ps. open with XL
File Type: wmf
Trailing split.wmf (605 Bytes, 310 views)
Old Mar 30, 2005 | 08:19 AM
Coyote
no opinions??
Old Mar 30, 2005 | 03:56 PM
well on boosted cars, especially high boost cars, i've seen people use the reverse curve that you are using.
for idle I use 5 degrees split as that helped pull a better vaccum when i was messing with split, as compared to 10+ degrees.
I've heard from ito and have seen in other tuners maps that the split increases to 12+ and as much as 16 degrees split in the mid to upper rpms when using high boost, to avoid any type of flame-front collisions
Old Mar 30, 2005 | 04:05 PM
eViLRotor's Avatar
Brother of the Rotary
I run basically stock split at idle (15 deg). Split in the cruise range is pretty low (5 deg). Under boost it ramps up to 15 deg split by 20 psi.
Old Apr 3, 2005 | 03:55 AM
Coyote
how the heck did i post that map???? i am running 8 deg split till 4500 9 till 5000 and 10 above five....
that table using some guidlines which dont make sense..
so i think my setup is good not that!!
Old May 16, 2005 | 08:52 AM
Coyote
hehe...you can alway take the split fom my map update....
Old May 16, 2005 | 08:54 AM
Coyote
for your sake though...
File Type: wmf
Old May 16, 2005 | 12:42 PM
nyt's Avatar
nyt
with the various dyno runs ive done, ive seen most power (car dependant) between 8-12 degrees of split.
Old May 16, 2005 | 02:47 PM
Coyote
in fact i run 8 till about 4500 then up to ten...
is it true that the closer the split the better the power, but worst on emmisions?
Old May 18, 2005 | 05:13 PM
nyt's Avatar
nyt
depends on the engine
i saw most power with 10 split
Old May 18, 2005 | 05:14 PM
nyt's Avatar
nyt
i think you have my split map haha =]
Old May 19, 2005 | 08:23 AM
Coyote
yep!! hehe and Mikes's idle split!! haha
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
