Microtech Microtech and what wideband?
Old Feb 28, 2005 | 03:07 PM
drivegrp's Avatar
What wideband do you guys prefer? I have an LTX-8 on a 2nd gen and will purchase a wb02 in the next few days. I'm looking for reliability and ease of use.
TIA
Old Mar 8, 2005 | 06:40 PM
ronbros3's Avatar
I use an LTX8 and a techedge W/B AFR both work great, I personaly would not run a rotary with out them , blew two engines into the next county using other types of EMS. thanks RON
Old Mar 16, 2005 | 09:40 PM
MrSparkle's Avatar
i'm disrespectful to dirt
anyone using the zeitronix wb with their microtech?
Old Mar 17, 2005 | 12:01 AM
1sgen's Avatar
583 rwhp 1st gen
can you get the ltx8 to see the readings out of the wb for data logging and how do you hook it up?
Old Mar 29, 2005 | 12:35 PM
dr.jones63's Avatar
It's a Hammer
Im new to microtech and I have the same question as 1sgen.
Old Mar 29, 2005 | 01:39 PM
Arvika's Avatar
I'm buying a Zeitronix...
Old Mar 29, 2005 | 09:41 PM
FC_mania's Avatar
well i thought the LT8s doesnt have a wideband input for datalogging?
Old Mar 29, 2005 | 09:52 PM
MrSparkle's Avatar
can someone confirm this?
Old Mar 30, 2005 | 07:08 AM
Arvika's Avatar
There is a Black/red wire in the Microtech LT8 harness marked Oxygen sensor!
Old Mar 30, 2005 | 12:00 PM
Trav's Avatar
Come on guys... if you search this, you'll find all sorts of info!!!
LT8 (& LTX8) does NOT have a WB input (0-5v). It only has a NB input (0-1v). Now some guys are trying to get around this by using a WB sensor/controller that has a NB output and hooking that into the NB input on the LT8. I think some guys are having some success at that, but have mentioned that it's not extremely accurate like a true WB signal would be. My theory here is that you need a true linear 0-1v signal to feed the LT8 to get anything accurate.
If you want true WB datalogging, you're going to have to upwards of the LT8 (or LTX8).
btw, Search!
Old Mar 30, 2005 | 03:08 PM
stacher's Avatar
The LT12 series is enable for wideband. The LT8 is not. The problem (as Trav stated) is coverting the signal to narrowband. In other words with the Microtech parameters . (0v =9AFR and 1v=18afr). However, these parameters can be programed by Microtech. Expect to spend about $300 when all is done .
Old Mar 30, 2005 | 03:11 PM
Arvika's Avatar
Lt10 ?
Old Apr 1, 2005 | 03:25 PM
dr.jones63's Avatar
It's a Hammer
In theory a resistor could work.
0v=9AFR and 1v=18afr
0v through resistor = 0v = 9AFR and 5v through resistor = 1v=18afr
Old Apr 1, 2005 | 08:54 PM
dr.jones63's Avatar
It's a Hammer
TIA
You could get a laptop with 2 serial ports and run a inovative in one window and microtech in another.
Old Apr 1, 2005 | 09:18 PM
MrSparkle's Avatar
^that's what i'm going to do with a zeitronix
Old Apr 2, 2005 | 02:27 AM
dr.jones63's Avatar
It's a Hammer
hmmmmmmmmm
http://www.plxdevices.com/NB_WB_GaugeConv.htm
http://www.zeitronix.com/Products/Products.htm
Old Apr 2, 2005 | 06:01 AM
stacher's Avatar
Yes, but the idea is to have it all logged in one "data log" (Microtech's).
Old Apr 2, 2005 | 08:31 PM
dr.jones63's Avatar
It's a Hammer
I was thinking of getting a WB probe and running it to a PLX converter ($35) and then to the microtech NB input. PLX states the converter is only for use with a PLX WB controller. So I just bit the bullet and ordered the zeitronix.
Old Apr 13, 2005 | 08:16 PM
puntorotary's Avatar
Rotary Mechanic
Whats the advantage of wideband ? Sorry fellas im old school straight Holley man and bridgeport, just trying to learn about all this other stuff since i have a TII now.
Old Apr 23, 2005 | 09:04 PM
Rotary Mechanic
does the LT 10 have have datalogging?
mulcryant
Oct 4, 2015 12:18 AM
