Coolant Lines
Old Feb 28, 2005 | 01:21 PM
AntiVenom7's Avatar
Wouldn't Go If U Paid Me
Coolant Lines
OK, I searched the forum, but found nothing conclusive. So, here is the question:
How are you guys running/routing the coolant lines into the center housing (i.e. what are the sources for feed and return)?
Thanks in advance for the help. I think I have an idea, but just want to make sure I am thinking about it right.
Regards,
Josh
Old Feb 28, 2005 | 07:24 PM
AntiVenom7's Avatar
come on guys don't make me feel like a ****.
Old Feb 28, 2005 | 07:29 PM
the_glass_man's Avatar
Will u do me a kindness?
Thermostat housing. Just like the stock turbos.
Though now I'm thinking of using the rear nipple on the back housing and heater line supply on the rear housing because I removed the thermostat and water pump.
Old Feb 28, 2005 | 07:36 PM
AntiVenom7's Avatar
thanks that is what i thought, but wanted to make sure.
Old Feb 28, 2005 | 08:07 PM
Rotarded's Avatar
"Challenged" since 1993
Since I have bypassed the T-body, would the rear housing nipple work as a supply? Then return to the back of the filler neck above the coolant sensor?
I ask this because I need to supply two turbos and there isn't a lot of room to run both to y's and then to the stock locations.
Old Mar 1, 2005 | 05:30 AM
AntiVenom7's Avatar
good question.
mulcryant
Sep 9, 2015 05:24 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
Nosferatu
Sep 5, 2015 02:13 PM
