What else do I need for this single Project?
Old Feb 25, 2005 | 04:12 AM
dhahlen's Avatar
FD Under Construction =P
Alright, these are the parts I have. I have never done a single install, and I need to know what I might need aside from what I have here. I don't want to get it all setup and tuned and then break something, haha.
Here is the list of parts I have:
TD08 Turbo
Manifold
Wastegate
Oil Lines
Apexi GT Intercooler
Koyo Radiator
Greddy Pulleys Installed
ACT 6 Puck Clutch and Pressure Plate
Racingbeat Light Flywheel
JACOBs Ignition System w/Harness
Rising Rate Adjustable FPR and Fittings
650/1300cc Injectors that fit in stock Rail
Apexi POWER FC Installed w/Commander
Torque Brace
HKS SSQV Blowoff Valve
Greddy Elbow w/bungs
MAP Sensor (to replace stock 17psi limit)
MAzdaspeed Short Shifter
Blockoff Plates
New Spark PLugs
New Spark Plug Wires
I have a few extras but they really dont have anytihng to do with a single...
C-west Original Front Bumper
Replica Sides and Rear
C-west headlights
Scoot CF Hood (On the way)
99 Spec Lights (on the way)
I figure I might need some new differential bushings, or some other crap. I got silicon lines in my engine, but the rats nest is going to disappear anyway.
I just want to gather up some things that I will be needing.
Also, anyone have a estimated RWHP on this one?
Thanks!
-Darren-
Old Feb 25, 2005 | 04:51 AM
dhahlen's Avatar
Forgot, I have an AVC-R Also
Old Feb 25, 2005 | 05:15 AM
maxcooper's Avatar
WWFSMD
Do you have an FPR with a 1:1 rate (Aeromotive, etc. -- an adjustable FPR with manifold reference), or is it really a RRFPR (>1:1 rate increase to outmatch the boost, usually round in shape)? Since you already have a programmable ECU, I would only recommend a 1:1 FPR and not a RRFPR. There is no sense in having useless variables/adjustments by adding an RRFPR.
Note: I know that 1:1 FPRs are sometimes called RR FPRs in catalogs and such, but I think that is misleading since the flow rate of the injector is really held constant (rather than rising) when the manifold pressure changes.
I recommend getting a Datalogit and a laptop computer so you can do better programming on the PowerFC. Wideband O2 sensors are available for reasonable cost from a lot of places now, too. A wideband is essential for tuning, though you could always have someone tune it that uses their own wideband rather than installing one permanently in your car. However, I like having my own wideband hooked up to the Datalogit for logging and tuning.
-Max
Old Feb 25, 2005 | 05:18 AM
dhahlen's Avatar
Max, thanks bro... I am going to take it to XS for tuning, and it is a rising rate =/
Thanks
-Darren-
bigtuna
Oct 8, 2015 10:01 PM
risingsunroof82
22
Sep 22, 2015 01:20 PM
ZacMan
Sep 19, 2015 09:20 PM
