What Else Do I Need For 20psi On A T04e??
Old Dec 18, 2001 | 09:33 PM
LUV94RX7's Avatar
Oldie, but Goodie
For all you single turbo high psi guys - What Else Do I Need For 20psi On A T04e. What do you recommend for extra components to run at this high psi. I'm hoping for about 450rwhp peak with a nice power curve. I'll be running 100 octane race gas at this high psi. Dave at KDR will be doing the dyno tuning.
Ken, 57 years young
'94 white, base, pep, red leather,
mods: street port & polished stage II, 2mm Hurley Racing seals,
XS T04e single turbo kit, SMIC(400cu.in.) Aquamist 2s water injection kit, Pettit ss resonated MP, Pettit ss cat-back, RP Racing fuel pump, 1200cc injectors, Profec B(10&20psi), Centerforce clutch, under pulley kit(no air pump), Pettit short shifter kit, boost gauge,
LaBreck's bushings, Evans Coolant, www.nopistons.com
Old Dec 20, 2001 | 08:30 PM
ErnieT's Avatar
Living life 9 seconds at a time
Sup bro......
A couple things. For one, you'll need to pitch the 1200cc secondaries in favor of the 1600cc/fuel rail kit. Two, pitch the Power Fc in favor of the Haltech. Three, 20lbs of boost is alot of boost. Even w/ race gas you'll be pushing your motor pretty hard so be careful. And make sure you have enough fuel pressure, although you should. Good luck!
V8HUNTER
Apr 10, 2006 07:03 PM
Silver7
Dec 24, 2001 06:50 AM
LUV94RX7
Rotary Car Performance
Oct 5, 2001 04:52 PM
