HELP is my oil pump pumping enough oil(oil pressure probs) video inside.need help now
Old Feb 19, 2005 | 02:32 PM
felixwankel88's Avatar
Well i wasent geting any oil pressure when all toghtor so i took it apaet and this is all the oil pumping when cranking engine, should i just put it toghhtor and just fire it up.. or try get it to pump more please help asap
http://www.club-swat.com/~felixwankel88/MOV01346.MPG
please tell me asap cuz im working on trhe car NOW
Thanx
Dustin
Old Feb 19, 2005 | 02:43 PM
inflatablepets's Avatar
Somthing really seems wrong. I don't know what to tell you as I can only give advice from my actual experiences. I have had no issues with oil pressure before. I wonder about a pick up tube issue or the pump itself. I've heard that these pumps never go out either. Oh, you are getting sloppy with your spelling, grammar and punctuation again. You might want to watch it.
Old Feb 19, 2005 | 02:44 PM
DubbayoC's Avatar
i'm pretty sure there is a test proceedure in the haynes manuel.
Old Feb 19, 2005 | 02:58 PM
im sorry about the spelling, mabee itz just because im ******* pissed off at the rx7 and world rite now, and the spelling is the least of my worries rite now, anymore advice would be really nice
Old Feb 19, 2005 | 06:33 PM
RotaryEvolution's Avatar
Sharp Claws
seems like an oil pickup tube problem, the gasket probably slid sideways and is either causing an air leak or blocking the flow partially, the oil pump is working but you need to check the system further up which means the passage through the block down to the pick up tube mount and the gasket and pickup tube istelf, seems like there is a blockage or leaks in that system somewhere.
is the oil pan smashed in possibly as well? if the pan is smashed in it could be blocking the pickup tube also, some thigs to look for. seems like it is cavitating..
don't start the engine because that is not enough to supply your oiling system. in fact i would prime the system manually by pumping oil down through the oil filter pedestal into the engine to lubricate the bearings.
Old Feb 19, 2005 | 06:36 PM
HAILERS's Avatar
HAILERS
You've probably already done it, but pull the pump off with the gear still attached. Then rotate the gear while looking into the aft side of the oil pump. See if the internals are turning. Also look on the outside of the oil pump housing. There should be a very small screw that is staked in the side of the housing to hold the outside gear in the pump. If it fell out thngs won't work right.
If the pump looks good, and then I'd pull the pan and see if there is something irregular with the strainer/pickup. then look at the oil relief valve in the bottom of the front cover to see if its stuck open.
There are gap measurements in the oil section of the fsm for the internal gears of the oil pump. I really doubt that would be the problem the way that pump is pumpin.
Old Feb 19, 2005 | 07:49 PM
prob solved thanx for the help
Old Feb 19, 2005 | 07:53 PM
Rxmfn7's Avatar
Do a barrel roll!
Care to let everyone know what the problem was, in case this happens to someone else?
Old Feb 19, 2005 | 08:13 PM
pengarufoo's Avatar
The mystery of the prize.
no kidding wtf
Old Feb 19, 2005 | 08:18 PM
sorry, i just got the engine running and i waz really excited to go out and run it.. the prob was the oil pump was put toghor wrong the 2 dots on the bottom and 2 dots on the top wernt alioghned like the FSM saifd they needed to be
Old Feb 19, 2005 | 09:22 PM
Adam's Avatar
NM
Old Feb 19, 2005 | 10:12 PM
Kenteth's Avatar
Like Ghandi with a gun
I once forgot to to reinstall the uperradiator hose when i was excited to see how well (or badly) the electric fan would do on a quick cruise. The add coolant light did come on about 3 miles from home btw...
Snoopy FD
Dec 8, 2015 01:45 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
