how many miles did you go before rebuild on NA FC?
Old Feb 18, 2005 | 06:47 PM
gentlejax2's Avatar
I have one with 98K runs fine. I just bought one with 121K ...dont know yet.
jsut curious what other have gotten with their FC. my 2 12A's lasted 150K+ miles
Old Feb 18, 2005 | 06:51 PM
Schmitty's Avatar
Registered User
I bought one with a blown engine at 101k...
Old Feb 18, 2005 | 06:56 PM
Project84's Avatar
Open up! Search Warrant!
bought one with a blown coolant seal at 114K. You know that part that the pressure cap screws into on top of the water pump housing? Someone replaced that with one that didn't have a tube for the over flow bottle. There wasn't a pressure cap on the radiator, so the pressure built up inside the block and blew the seal.
Old Feb 18, 2005 | 07:02 PM
Jodoolin's Avatar
My new '90 na went 228,400+ before rear rotor blew. Replaced with Mazda reman. Junked it at 350,500 and motor still stone solid
Old Feb 18, 2005 | 07:26 PM
felixwankel88's Avatar
ok one fc i have blew up at 146k
one at 60k
one at 9k
and one at 141k
ide say u got till at least 140k(the 9 k and 60 k were buy the same owner which says he beats the livving shittg outta them)
Old Feb 18, 2005 | 07:36 PM
fc3salb's Avatar
0 Pistons+0 Valves=Happy!
Mine blew at 156K. Damn coolant seals... replaced it with another motor this month and here I am.
Old Feb 18, 2005 | 08:37 PM
KillaKitiie's Avatar
Bongolio
mine got 180,000 and i put about 60 miles day on it.87 gxl
Old Feb 18, 2005 | 09:12 PM
Froggmann's Avatar
Ring ading ading
The original engine bought it at 217,000 Mi. Oil seal.
Old Feb 18, 2005 | 10:31 PM
89tracerman's Avatar
152K miles, minor blown coolant seal added CRC block weld and its good to go any where
Old Feb 18, 2005 | 11:12 PM
andrew lohaus's Avatar
before i owned mine it blew a coolant seal at about 95k, i cant say much for how the car was maintined and such for that period as im third owner and most of those miles were done by the first owner. if well maintained 200k if pretty common on a stock n/a.
Old Feb 19, 2005 | 09:06 AM
ViperDude152's Avatar
Rotary Power Information
mine is at 155K+ miles right now and still runs like a champ. I know it will run well voer 200K cause im using 2 stroke oil so i will have WAY less carbon built up then the OMP users. I have overheated my engine abuot 10 times for diff reasons. everything still works. The ONLY thing i see getting warn are my oil seals. I get smoke on a highrpm decell. but nothing horrible. eventually im sure its time will come with the oil seals. but the engien wont blow
Old Feb 19, 2005 | 09:41 AM
LookThatsMe's Avatar
mine blew at 197k and im switchin motors tommorow got a great deal... 600 for motor andtranny wit 40k miles/perfect compression
Old Feb 19, 2005 | 10:33 AM
uRizen's Avatar
XBL** Ownicus
I'm at almost 114,xxx and I still pull 100 rear, 110 front for compression. I only get some reaking fuel smoke at startup (revving to 3k before shutting down helps this), but other then that she doesn't burn any fluids that aren't supposed to be burned, and it pulls hard.
After switching to premix, I did notice it became overall smoother in operation, and now I can switch to synthetic when I finish blocking the OMP off. I hope to get this thing past the 200k mark.
Old Feb 19, 2005 | 10:42 AM
SirCygnus's Avatar
whats going on?
well, i have 180k miles on it and i kick its *** every day. i rev it hard, and i drive it hard, but thgen again i dont keep it up at redline all the time. compressions seems to be pretty well. i was getting around 90 psi when it was cold so it should be even more when warmed up.
Old Feb 19, 2005 | 03:27 PM
OMEGAMANRX7's Avatar
OMEGAMANRX7
I bought mine with 147309 miles on it with a broken speedometer still to this day. I'd say I put at least 10,000 miles and it still runs strong. It all depends on how you treat the car, with respect or with a passion to smoke the hell out of the F@#king civic nation.
Old Feb 19, 2005 | 09:04 PM
slpin's Avatar
7th Heaven
my friends automatic 88 gxl hit 225k before she sold it...
hot starts too... all original
Old Feb 19, 2005 | 10:19 PM
trent1059's Avatar
bone stock vert
172589 still ran strong just smoked a little on start up and flooded on occasion. I can really tell the difference in the power, she was tired
Old Feb 19, 2005 | 11:00 PM
Wizz's Avatar
177,000 then pop. Apex seal.
Rebuilt the motor myself, now has 200,000
Old Feb 19, 2005 | 11:06 PM
KarmaWeasel's Avatar
Define 'Cynical'
Previous owner of my car had the engine replaced at 81k because, as the diagnostic paper says, "It was melting the rear bumper". She would shut it off during the cold start assist, never redlined it, etc. Basically, she didn't know how to drive or take care of a rotary... I'm surprised it lasted as long as it did.
Old Feb 19, 2005 | 11:08 PM
Adam's Avatar
got my 88gxl with 119k . Now has 140k runs ok besides flooding every freaking morning and fuel smoke coming out at start up...
Old Feb 19, 2005 | 11:10 PM
Kory_yahi's Avatar
Look ma'! I am spoolin'!
88 gxl, 107,xxx on original engine, 125/125 compression
Old Feb 20, 2005 | 12:33 AM
capn's Avatar
Mechanical Engineering
128,xxx on my first FC and now at least 50,xxx on my 10th AE dont know really how many miles cause the odo. is broken. i have a new one im just lazy
Old Feb 20, 2005 | 12:47 AM
RE-Renegade's Avatar
199,xxx orginal mileage on my 89 GTU, i probably redline it once in a while to keep things going, no signs of weakness still going strong. keeping a strict maintenance schedule really helps.
Old Feb 20, 2005 | 01:03 AM
staticguitar313's Avatar
R.I.P. Icemark
my car was sold to me with the engine replaced its had 29,xxx on it when i got it i've only put about 2000 on it
Old Feb 20, 2005 | 07:49 AM
ronyrx7's Avatar
110 and still strong 110 comp on both rotors
